Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
I just installed a new cartridge in a moen single handle bathroom faucet. Works great except no hot water. The hot water valve is turned all the way on.
  • Joseph Weisenberger
    Joseph Weisenberger May 11, 2010
    Did you turn the stop back on before you put the escutcheon to the wall?
  • 117 Answers
Try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
Posted on Jul 29, 2009
The faucet drips constantly from a single handle tub. How do I fix this?
we would need a little more information but sounds like it will need replacement, The water will eat up the meatle and make a rebuild impossible sorry but no quick fix the hot water lineis usley the culprit
Aug 09, 2017 | Plumbing
No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
Soak the dirty cartridge in vinegar for four hours and replace.
If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
The moen began to leak over time now i cant turn the water for
Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
The hot water is not working at our tub. we had the water turned off for a couple months and I believe sediment is in the line. The hot water works everywhere except at this one tub. i need instructions on...
Your problem is most likely a bad cartridge.#1 turn off water in house #2 remove handle #3 you will see a horseshoe shaped clip that holds in cartridge remove clip and try to pull cartridge straight out you may need to purchase a moen cartridge removal tool for easier removal and install new cartridge and replace horseclip
Nov 14, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Jul 02, 2009 | Moen 2919 Chateau Two Handle Tub and...
Plumbing
Hi rbyerly,
I'm Harvey the Master Plumber.
Your problem is:
remodeled bathroom,installed new moen valve and hardware. Now water is coming from both the shower head and the faucet when the diverter is in the down postion. Question; Is this a single handle or three handle diverter? Assuming it's a three handle, it should just be a mater of adjusting the center handle. If single, the diverter is in the spout not the valve. I don't know how to direct you further without specifics. Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 06, 2008 | Home
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
429 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
