Question about Sanyo Televison & Video
LCD-32 TV.Can not tune in channel 7
Can not tune channel 7? Can receive ATV 7 and SD 7 on another Set-top box LCD-32XR8DA TV
  • Anonymous Mar 26, 2014
    VOL WANT TUNE DOWN ON TV SET
81CM HD Sanyo LCD: Was still under warranty, took it recommended repair man and he simply tuned it at his shop!. Perfect when I connected it at home...Bob Tape
Posted on Jul 29, 2009
Will this model receive 7flix and other new channels? If not can we get a set box to get them
if your tv is already receiving digital stations the it will receive 7 flix
If you are already using a set top box it will get 7 flix and all the channel 9 station as well
all you have to do is use the remote to get the on screen menu up, (press the menu button) --navigate around until you get the auto tune in channel selection auto or manual---select auto tune and let it go and all the extra channels will be programmed in
Mar 10, 2016 | Televison & Video
Sanyo LCD 32XR8DA i cant turn the tv on by remote or by pressing the button on top of the tv
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 26, 2014 | Televison & Video
My problem is I have a dvd player DMR-ES 15 I live in australia is it possible to tune in the new tv stations example seven 2
It is not possible to tune in 7two, channel 11, GO! or similar digital channels with this model DVD recorder, as its tuner would most likely be analogue only. You would either need to upgrade to a model with a digital tuner built in, or purchase an external set top box, capable of SD and HD digital reception, and connect its AV outputs to the respective inputs of the recorder, in order to record the channels you want.
However, being in OZ, those digital channels are available as free to air - all you would need is the appropriate receiver to enjoy them. I recommend a set top box which offers HD as well as SD.
May 05, 2011 | Panasonic DMRES15 DVD Recorder
Turn on goes blue then turns off
The most common reason for a TV to display a blue screen with no picture is because the source device has not been set to the proper mode.
If you are using a cable or satellite set-top box, ensure that it is turned on and set to an active station. If the set-top box is connected to the television using a coaxial cable, then the television should be set to Channel 3 or 4 to receive the signal.
If you have are using a VCR that is turned on, but not playing a tape and not tuned to a receivable channel, then a blue screen will be displayed on the TV. To resolve this, turn off the VCR or tune it to a receivable channel. If a cable or satellite set-top box is connected to the VCR using a coaxial cable, then the VCR should normally be set to Channel 3 or 4 to receive the signal.
If the blue screen is not because of a connected VCR or set-top box, the TV may require service.
Sep 22, 2009 | Sony KP-57WS500 57" Rear Projection...
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
Panasonic Viera LCD TV Can't Find Channel 7
I can't receive channels 3 and 6 right across the Delaware in Philly. Welcome to the club.
Aug 15, 2017 | Panasonic Viera TC-L32C12 32 in. LCD TV
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
HDTV and cable box; no volume on channels higher than 99
Can you tell me, is the set top box connected directly to the tv? (i.e. not to a surround sound receiver or anything)
Mar 13, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
How to set SONY TV # KLV-S32A10 to receive HDTV channels?
the new lcd tv you have will pick up hd channels. run the autoprogramming for the channels for sd and hd. be prepared for about a 20 minute wait
Jan 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Recording digital channels
Connect your set top box to Scart L2 (the Right hand one).
Select Prog 1. Then Channel down until you get to L2.
This should work.
Jul 12, 2008 | JVC DRM10 DVD Recorder
Televison & Video Logo
221 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
