Question about Maytag Atlantis MAV8000
Machine does not turn off even if the cycle knob is pushed down in the off position. Water continues to flow when the machine is in the off position
    President:
  • 1,136 Answers
Hi, you will need to change the inlet mixer valve. It has stuck in the open position.
I hope this helps you. If you need part # or any other assist ance, please let me know.
Thanks
Vic
Posted on Jul 29, 2009
    President:
  • 1,865 Answers
Sounds like water solenoid valve has failed, it is fairly easy to replace. Valve is located near water hose connection
Knob won't work
Easy check for water filling problem like yours. Unplug the power and see if water still flows into machine. If yes----your inlet valve on the washer is stuck open and needs replaced. It is the part on the washer back where your fill hoses attach to. If the water is flowing into the machine while plugged in and it stops when unplugged, you have something in the control panel sending power to that inlet valve even when the machine is off. You would now need to find out where the power is coming from. If its an electronic control washer, the main board may need replaced.
Apr 11, 2015 | Washing Machines
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch diameter.it sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
How do I de calcify?
HI
The Digital Italia is programmed to descale the boilers on its own. With the machine turned on, push and hold the descale button (bottom right button). This should say "Descaling" in the display. Mix your descaling crystals in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, the display will say "Finished descaling" push any button to continue. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, push the descale button again, then close and then open the steam knob again to let water just flow through the boilers until it is emptied by the machine, but don't turn off anything until the machine stops again on its own. This will clear the descale if you have gone to the "Reset Descale" in the menu and chose "Yes". Refill the water tank again with fresh water and then close and then open the steam knob again to prime and your ready to go.
Feb 17, 2011 | Starbucks Saeco Italia Digital Barista...
How do I descale the Starbucks Barista Italia Digital machine? There is no "descale" option on the menu list like other machines I've had. I received this machine as a slightly-used gift with...
The Italia is programmed to descale the boilers on its own, when set in the correct mode. To program the machine to descale it's self, do the following. With the machine turned on, push and hold the descale button (bottom right button). This should light the top right red indicator light. Mix your descaling crystals in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the top will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, push the descale button, then close and then open the steam knob again to let water just flow through the boilers until it is emptied by the machine, but don't turn off anything until the machine stops again on its own. This will clear the descale light. Refill the water tank again with fresh water, then open the steam knob to prime the machine and your ready to go.
Feb 14, 2011 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Won't stop filling with water
Does the water continue to run when the washer is unplugged from power?  If it does, then there is something stuck in the inlet valve that is keeping it open.  Could be the result of mineral deposits.  If the water stops when unplugged then the water limit switch is defective.  Unlikely since the water still flows when control knob is in off position.
May 29, 2009 | Washing Machines
Water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Apr 11, 2009 | LG Washing Machines
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Open Questions:
Washing Machines Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
