Sharp standard tv turns off by itself. have to
My sharp standard tv turns itself off after it has been on for an hour. Right before the screen goes black the picture goes to a black vertical line in the center of the screen with a dot in the middle. The power actually goes off on the television. We have to wait over a half hour before we can turn it back on otherwise it happens again.
    Champion:
  • 252 Answers
If you know how to solder,resolder the vertical section of your tv especialy the IC.i think it is TDA 3657 it is an IC with 7 to 9 legs
Posted on Jul 29, 2009
Sharp TV keeps turning off every 3 hours by itself. Have to manually turn back on. Will not work by remote.
Check whether its \off timer' function is set to 3 hours. If it will not work with remote control, you can't check this function.
Oct 27, 2013 | Televison & Video
My sharp LCD tv won't turn on,it goes off after a few seconds.
Time for a new TV. or you might unplug it let it set for a while and then plug it back in see if it reset itself.
Mar 13, 2013 | Televison & Video
Sharp lc-32d4ou screen blacks out
I do have a work around that I have used on this model for the past3 years. if the sceen goes black. Turn off the tv. Grab the upper left and right hand corners of the tv with your hands. Flex the tv slightly back and forth. then turn it back on. my will usually run for hours after I do this. I do this 4 times a week. I works 100% if the time for me. Sharp lost a customer. good luck.
Aug 31, 2010 | Sharp Aquos LC-32D40U Television
My flat screen 12 inch sharp Tv has a black sqaure apparening when I change chennel or do anything with remote. It only goes away when pressing the vol. botton the a few minutes later show up again. please...
Your closed captioning mode is set to ON. You need to just turn that off. That setting is available through the on screen menu. Just turn closed captioning off and it will work normally again.
Apr 16, 2010 | Zenith C27A24T 27" TV
TV TURNS OFF BY ITSELF
Sounds like the Startup Relay is dropping out, you will need to replace it.
Mar 28, 2009 | Sharp 32L-S400 32" TV
Screen goes white
you may have a solder joint or an electronic part that is beginning to fail. have an electronic expert look at it.
Feb 07, 2009 | Sharp 25R-S100 25" TV
Sony FD Trinitron KD-34XBR960 34" TV
Our set turns itself off by itself. Prior to this happening, it goes to a green screen. It usually happens after the set has been on for a couple of hours. We bought the set in April, 2004 and the warrantly has now expired. The longer we keep the set on, the more it turns itself off. Is this a tuner, on/off problem or the tube? Any estimates for repair?
Jun 15, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Sharp TV switches to "input 2"
Mine does the exact same thing. I've had it for a few years no, and it just started doing this. It's so annoying. I don't think the weather has anything to do with it, though. It started switching itself just every once in a while, not it is almost every time I turn it on. Sometimes it takes an hour or so to start doing this, other times it's right away. Help!!
Jan 20, 2008 | Sharp 32C-240 32" TV
Aquos Turns off by itself
no. It goes black, then about 5-10 seconds, it turns itself back on.
Jan 01, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
View timer is stuck on
take your set to a tech your problem is more a technical problem that sounds as you are having a chip problem that controls the timer
Feb 16, 2007 | Sharp 55R-WP4H 55" Rear Projection...
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Electro Med Services...
