Question about Sanyo DP42848 LCD TV
Can i use tv as computer screen
What cabel would i use to make my tv my computer screen?
    President:
  • 563 Answers
The same VGA cable you would use to connect it to a computer monitor.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 29, 2009
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
This TV has 3 HDMI inputs (digital) but no VGA input (analog). Therefor you can not use a 15 pin VGA to VGA cable. Your computer needs to have a DVI output. You may need to get another video card with DVI. You can then get a DVI to HDMI converter and then use an HDMI cable. You will need to use the HDMI 1 port for video and a separate audio cable from the computer audio output (usually green 1/8 inch jack) to the TV audio input (white and red RCA jacks).
Posted on Oct 30, 2011
Dell latitude screen size
you can try adjusting the resoloution by right clicking any open spot on desktop
Mar 23, 2013 | Dell LATITUDE Computers & Internet
Connect tv to laptop
For connecting your laptop to your TV..you should have a HDMI cabel.
Connect it to your laptops HDMI port and then to the tv's HDMI port. Wallah - Now..Your tv is your laptop screen !
Thank You.
Dec 27, 2012 | Emerson Televison & Video
Hello, can connect it to my laptop and view the screen on the tv screen?
type of you laptop and see if you have VGA port in your laptop and in the TV screen or HDMI in laptop and TV screen after that used the cabel and press F5 in the laptop
Oct 03, 2012 | Computers & Internet
No signal to tv
your av cabeles could be on the wrong setting try to change from hdmi to tv on the end of the av cable that goes into the xbox. if it still dosent work then try to change the imoprt slots or try your cabels on another tv to see if its your cables thats the problem if you get signal on the other tv then its your first tv. but if you dont your av cabels mite be going i sugjest buying a new set if the other options dont work
Dec 11, 2009 | Microsoft Xbox 360 Console
Picture on tv keeps going out and coming on
If the previous posts didn't fix youru problem, and I doubt they did, then you most likely have a weak CRT and the video is being muted. you can sometimes tell if that's the problem by turning up the screen voltage slightly to see if the picture comes back on. If it does, then the CRT is weak. This is a very common issue with Sony CRT TVs, and can sometimes be rejuvenated by a good shop for fairly cheap.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
Loewe 30" tv turns on, message "no signal"
first thing I would do is to make sure your cable box is turned on. if not fixed, make sure you have the correct input. this can be done by viewing all the inputs that the tv has by pressing the input button on your remote until you find a picture. if it is still not working, make sure you have you cable run right. there should be one cable running to the cable box and into the port labeled antenna or input, then anouther labed cable running from the output port to the tv. there might also be a vcr or dvd play inbetween. if that is the case, the cabel running from the cable box should go to the input of the vcr or dvd play and the output line should go to the tv. any equipment inbetween the cable box and tv should be turned on when viewing you cabel tv. you will also have to make sure that any equipment inbetween is running off the cabel input.
Jul 04, 2009 | Loewe Aconda ACO9303 30" TV
Problem with VGA
dear if you dont have download it from
click here
if you have then change it to multiple screen
mvmanish
May 10, 2009 | Toshiba Satellite A205-S4607 Notebook PC
Sanyo DP42848 LCD TV Logo
354 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
