Washing Machines Logo
Farid Amirian Posted on Oct 18, 2017
My pump flashing code 4329 - Washing Machines
How to turn the rely back on to the fuel pump
as always check all fuses FIRST (electrics issues, EFI is that.)
the Puter magic is mindboggling, but..
why not post the symptoms, ????????
is it dead fuel pump or the more accurate, low or no fuel pressure?
All ECU/PCM (EFI ) all cut the pump for many reasons.
PCM is PGM-FI , in honda speak. PCM is modern term.
first really is fuse checks. !!!
1: no spark. (did you pull the CEL DTC blink codes to see if the ECU
is unhappy?
2: many cars (you must crank to run the pump) so looking not cranking for 12v at the pump , you fail and is normal.
(2 man rule one to crank, one to listen or check voltage at pump
or pump pressure at rail or filter) (a new filter is a good ploy now)
the fsm is here, and covers this, read the FSM
some pages are missing,,, so get real FSM
or go to alldata.com
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
free but , some pages missing(good luck with free)
http://hondatech.info/downloads/Auto/Manuals/Accord/
see chapter 16, electrics.
F22A6 engine
this page is valid.
http://troubleshootmyvehicle.com/honda/2.2L-2.3L/how-to-test-the-fuel-pump-2
I like the (above) is cam dead?, line.... funny that.
(gather evidence, fuses good, cam spins (watch it) no DTC stored.
then check for spark no spark work spark now ,not fuel.
with a dead cam there is no CMP , no CMP the ECU pukes
codes for CMP Dead.
this is an interference engine so i'd bet that belt is fresh, huh?
ever 60k? per the opr; guide.
watch for codes, 4,8,9,15,16 (OBD2 DTC codes)
code 9 is dead cam. dead spark and all fuel is cut. for ever.
TDC&crank sensor, must work and not show DTC codes.
http://www.troublecodes.net/honda/hondadtc/
DTC flashing? The DLC jumper:
On 1990-95 Accord (except V-6) and 1992-95 Prelude, the codes are read from the check engine light after the two-wire service connector has been jumpered. On Accords, the service connector is under the dash on the passenger side. On Preludes, it is located behind the center console. Codes 1 through 9 are indicated by a series of short flashes; two-digit codes use a long flash for the first digit followed by the appropriate number of short flashes. For example, Code 14 would be indicated by 1 long flash followed by 4 short flashes. Codes are separated by a pause between displays. Multiple codes are transmitted in an alternating pattern. For example, a code 3 and 14 would be displayed as 3 short flashes (for Code 3) followed by the separator pause, then 1 long flash and 4 short flashes (for Code 14).
if fee for you , this very old car, so here is your long lost oper guide
http://justgivemethedamnmanual.com/honda/
Need the authorization code. serial number: 1045-0813-7242-5479-7059-4325 activation number: 4105-3169-1037-8887-6181-7417-2183-4329 typ: repair 93: -8 please send me to my mail-adress
visit the below links it can solve your problems
http://www.adobe.com/products/activation/
http://kb2.adobe.com/cps/100/1008779.html
Thank you
Keerthyinfo
7helpful
Machine error 77
Hello there, in a situation like this the best thing for you to do is to call Brother customer service at 800-284-4329 and explain the problem.
Thank you
2helpful
Brother fax 2820 password
call brothers tech support.. its free and they will help you reset it...
In USA: 1-800-284-4329 (voice)
1-901-379-1215 (fax)
1-800-284-3238 (TTY service for the hearing-impaired)
In Canada: 1-877-BROTHER (voice)
(514) 685-4898 (fax)
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
2answers
Error 46 on a Brother MFc-8840DN
According to the Brother MFC 8840DN manual:
Machine error code xx: MFC has a mechanical problem
Solution: Call Brother customer service and tell them the error number
USA 800-284-4329
Remember to rate users who offer their expertise to you at no cost :)
Top Washing Machines Experts
john h
