Question about Home
We have a large cultured marble soaker tub with two hairline cracks going out from the drain, 1 about 18'' & 2nd about 24'' resulting in the tub leaking. The Tub is on the 2nd. floor & is sunken about 3'' below the floor surface through a cut out in the floor. From the side I can reach in with my hand between the floor cut out & tub to feel the area of the crack. If absolutley necessary I could cut out a piece of the gyprock ceiling of the room below in order access the bottom of the tub. I prefer not to have to do this. Your thoughts are appreciated. Thanks, Garry
    President:
  • 1,273 Answers
Hi Garry,
I understand not wanting to cut out the ceiling. Cutting it out is the easy part...Putting it back and making it look good....that's the hard part.
Just a few thoughts: You may be able to apply a coating from your access hole. What comes to mind to me is a 2 part epoxey with a relatively long cure time, to give you time to apply it. This can actually be applied with a small, disposable roller (shur-line makes a small one with a tray, ~$2). I have used this method on projects with success. If additional strength is desired, you can apply fibreglass mesh into the worked area just as you get tacky. Let dry and recoat. This can go as many times as you need to to get adequate coverage.
That was solution #1. Here's another possibility. Since it is a cultured marble tub, you may be able to grind out the cracks, collect the residue, and make a surface patch with resin and ground marble dust. Additional material may come from areas that you can't see, or perhaps you may purchase a damaged piece from a hardware/plumbing supply type store. I'd experiment with this one on some scrap before I went to gluing mama's tub though!
That was #2. One more, and I'll leave you alone. It's possible that you can find a spray coating that will do the trick. Such a coating could be applied laproscopically, via several very small holes in the ceiling, which could be easily repaired after.
Just a few asides While these may fix your immediate problem, be sure to find out why the cracks are showing up. Either the drain was overtightened, the tub was not properly cast, or the drain piping is supporting too much weight. Anything that you can do to spread the load of the weight of the tub, the water and as many kids as you care to put in there will go a long way in preventing the situation from recurring. Well, brother, just some food for thought. Hope that it helps.
Best regards, and good luck! Hopefully a garden tub guru will have a magic bullet they'll share with you!
--W/D-- Please feel free to rate this solution! Thanks!
Posted on Jul 29, 2009
11/8 two equivalent ratios
5.5:4, 11:8, 22:16, & 44:32 *all* have the same ratio. Additional equal ratios can be determined by multiplying *both* the 11 and the 8 by any number. Example (1): "5" 5 x 11 and 5 x 8 for a 55:40 ratio. It is much more desirable to reduce the numbers to lowest whole form - hence expressed as 11:8 ("8 to 11"). A second example using "3/4" (or the decimal equal .75) .75 x 11 and .75 x 8 for an 8.25:6 ratio. Again, whole numbers are preferable unless they get very large.
Jan 05, 2015 | Mathematical Technologies Inc. MTI Tristan...
Frigidaire dishwasher (FDB1100RHC2) is leaking from bottom right corner and it appears there are small hairline cracks on the plastic tub. Is there a way to repair them?
Hello - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, from what you have described it sounds like the springs or hinges may possibly be damaged, or gasket not sealing properly. I would strongly suggest contacting a professional to move forward accurately.
Oct 12, 2012 | Electrolux Frigidaire Professional Series...
Whats the result of E=mc²?
The result is E=mc². Here is more informmation if you are interested: http://en.wikipedia.org/wiki/E%3Dmc2
Sep 25, 2010 | Mathematical Technologies Inc. MTI Tristan...
I did not get the instructions for the pop up installation. do i put plumbers putty around the seal between the sink and the pop up?
yes.
however plumbers putty is not recomended on cultured marble tops. (one piece counter top with built in sink) it will stain and discolor the marble
I recomend using silicone for these tops, just make sure to let dry for a couple of hours before using.
the silicone will only go around the drain in the top of the sink, don't use the silicone anywhere else. I like to use a little plumbers paste around the rubber washer on the underside of the sink, and just a little bit on any threads.
do not over tighten, use your chanel lock pliers until it is snug. if it is a plastic pop-up, they can break easily, so go easy
Aug 11, 2010 | Price Pfister 048E0BC Catalina...
Multiplication table
x 01 02 03 04 05 06 07 08 09 ...
01 01 02 03 04 05 06 07 08 09 ...
02 02 04 06 08 10 12 14 16 18 ...
03 03 06 09 12 15 18 21 24 27 ...
04 04 08 12 16 20 24 28 32 36 ...
05 05 10 15 20 25 30 35 40 45 ...
06 06 12 18 24 30 36 42 48 54 ...
07 07 14 21 28 35 42 49 56 63 ...
08 08 16 24 32 40 48 56 64 72 ...
09 09 18 27 36 45 54 63 72 81 ...
Jun 15, 2010 | Mathematical Technologies Inc. MTI Tristan...
Well, I have the GE front load washer, model WBVH6240. I've got a marble stuck between the drum and the housing of the drum. It doesn't seem to be causing any damage, yet. Just makes a LOT of noise, so we...
I being a previous repairman, would not suggest to go ahead with it, the drum is a tough thing to work with and even I woud sooner live with the noise than go get it out,the drum is supported by a rear bearing that should not be effected by a marble,< best advice for you to try is unplug unit and tip forward until drum is level, with door open and shake drum to try to get it to fall into drain hose> if marble moves freely between drum and tub this will work,< the drain has a catch to prevent it from getting to pump. If you succeed at this then remove lower panel below door and there is a removable cap on drain to clean it out, remove cap< twisting it > and retreive marble. if marble doesn't move freely damage to unit may happen due to constricting movement of drum,< call repairman because it will require complete disassembly of the unit and not inexpensive either.
Apr 25, 2009 | GE WSXH208A Front Load Washer
Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Apr 24, 2009 | Home
I bought a model 2221 peanut soaker tub installation
fill the tub one third full with water you must be able to access the under side of the tub cut hole in drywall if possible spray two large cans of sprayfoam allow 5 hours for foam to set and drain water. problem fixed.
Mar 08, 2009 | Home
Home Logo
159 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
