SOURCE: Red Lines On Screen of Hitachi 43FDX01B
I also have the same problem. I've found that you can adjust each color of the screen by removing the speaker cover. Underneath you'll find a piece of partical board. Remove it. Looking at the front of the T.V. from left to right you will see the projector assembly for each color, red, green and blue. There are about six levers that pivot around each assembly. There factory settings are marked with white paint. By turning the ones on the red projector only you can manipulate the reds alignment on the screen. I don't know if it will work yet. My wife is the middle of adjusting. If anyone has a better solution please post it. I love my T.V.
SOURCE: PROBLEMS WITH VERTICAL ROLL
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
SOURCE: black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ [email protected] or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
SOURCE: My printer makes a loud noise when printing a line
Clean the printer head with some alcohol solution. And turn down the Density setting in the printer advanced properties to about 10.
SOURCE: one big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Hi clarence clark, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? model number
