Question about Hitachi 43UWX10B 43" Rear Projection Television
VERTICAL POSITION BLUE
I replaced the convergence on the tv and the red aligns but the blue will not budge the horizontial aligns just great but the vertical does nothing on the blue--red ok
  • 167 Answers
You have 1 of the resistors open or burned in the Blue circuit. Replace it before it damages the new IC's.
Posted on Jul 30, 2009
I have sony tv kp-65wv600. It has problems. color and video is blurry, double vision, letters are curved
You have a convergence failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless
Feb 24, 2011 | Televison & Video
The picture is producing a double image which appears to be in red only with a slight bending of the images on some parts of the screen.
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless.
Feb 20, 2011 | Panasonic PT-47WX49 47" Rear Projection...
The picture is warped red & blues distorted
Try This:
Note if one STK chip fails, you replace both regardless. They will be right next to each other.
Feb 20, 2011 | Toshiba 57H81 57" Rear Projection...
I have what appears to be shadowing of the words.. and picture.. blue wave across the top of picture..
Your Convergence ICs are likely failing. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Feb 20, 2011 | Hitachi 57SWX20B 57" Rear Projection...
I have a mitusbishi ws-a65 hd 1080 tv. im having trouble getting the picture to line up with the shodows, its showing double, how can i fix this?
Your Convergence ICs have likely failed. It is very common on rear projections. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Look for the converge option to align the red and blue colors
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Feb 20, 2011 | Mitsubishi Televison & Video
Tv is showing double images, not lining up
Your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My 65 inch sony tv half the screen is having colors like 3 d
Try This:
Feb 20, 2011 | Sony KP-51HW40 51" Rear Projection...
Picture is no longer working properly. Picture is blurry and colors are all wrong. Ghost image. Happened all at once not gradually. What needs fixed mitsubishi 65" medallion series. appox 7 yrs old
Try This:
Feb 19, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Convergence problem????
Yes Its the stk Packs,They are usally 18
Jul 23, 2007 | Toshiba 42H82 42" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
180 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
