Question about Welding Tools
Need the gun for a lincoln 3200 welder - Welding Tools
    Guru:
  • 1,326 Answers
Gonna be expensive About $125-$200. Sometimes its cheaper to get a new unit. They sell for about $300 on Ebay. I believe this will work on your unit Its $85 on ebay.
http://cgi.ebay.com/Lincoln-Magnum-100L-MIG-Gun-Replacement-10-150A_W0QQitemZ330349527430QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4cea5dc186&_trksid=p3286.c0.m14
Posted on Aug 09, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
NEED GUN FOR LINCOLN SP175 WELDER
iws.com bought my replacement from them about 110.00 with shipping dj.
Jan 24, 2013 | Lincoln Welding Tools
I hav a silver beauty 90200 mig welder and suddenly no power through whip to the gun.any suggestions that I may try to trouble shoot problem?
There is an inline fuse with the power feed to the gun, it may be blown. It is usually under the panel that exposes your connections for the gun/ wire spool.
Jan 17, 2012 | Lincoln Welding Tools
My wire feed quit feeding wire what do i need to replace to make it work
Hi:
If your drive rollers are moving but can't push the wire all the way to the end of the gun, your problem could be the liner in your gun and/or the contact tip. Try to replace both. If your drive roller are not moving then check the trigger of the gun.
Oct 03, 2011 | Lincoln Electric LE 83180 Century...
Will a Lincoln Magum 100sg spool gun work on a Lincoln mig welder sp130t
Hi:Lincoln Magnum 100SG were made for the lincoln 140 and 180. There is no spool gun control on the old SP130T.
Sep 10, 2011 | Welding Tools
Have a lincoln sp200. Trying to run aluminum wire not having any luck. I am running straight argon gas, I get basically a glow the wire melts no penetration. Do I need to reverse polarity or what. I...
Hi:
You should only reverse polarity only if, before you were using innershield wire on the same MIG welder.
Your gun should be connected to + and ground to negative and you should use a spool gun for it.
Argon gas is ok, but for thick metals 1/4" and above you should use a mix of 75/25 argon/helium.
Jul 10, 2011 | Lincoln Welding Tools
I own a Lincoln 305gas powered welder I recently purchased a Lincoln 25M suitcase and wanted to know if the two were compatible before I tried them together and if I can weld aluminum with them hooked up
Hi:
Yes your 25M feeder will work perfectly with ANY engine drive welder. Regarding the aluminum welding that's a no, sorry but suitcase feeder and gun are specialty made for mild and SS welding. For the aluminum you will require a spool gun and N adapter for your engine drive. Check you onwer's manual for more details.
If this was useful to you, please vote. Thanks.
Mar 27, 2011 | Lincoln Welding Tools
023 wire caught in line from machine to trigger on my 175 T lincoln welder
first stretch the gun lead straight ,unlock feed rollers try gently to real the wire spool backwards,if it wont move then cut the wire back towards the spool so you can take the gun off the unit lay it staight out use pliers and try hard to pull wire out.if that dont work you will have to replace liner.
Nov 29, 2009 | Lincoln Welding Tools
Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Apr 09, 2009 | Clarke Power Products Welding Tools
Welding Tools Logo
105 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
