SOURCE: Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
SOURCE: too much light in pictures
chack the white ballance and the EV +/- setting if possible set white balance to auto and EV to 0 (zero) or adjust the iso setting
SOURCE: I cannot use my camera outdoor, the picture is
if you know what you are doing then follow the following steps
set the ISO to 200
set the camera on P (program mode) and reduce the Exposure [+/-] to 0
now set to A (Apperture mode) and set it to 2.5
now set to S (Shutter Priority) and set to 1/25
well if you feel all the above procedure is a bit risky medling with the all important then just o to settings and reset to factory settings this will automatically set the Apperture, Shutter and Exposure settins to an optimal level and you can get back to clicking away again once you set the date and time
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps
I take the time to answer your question so please rate me
SOURCE: I have a wilife camera
Use the indoor camera as a test camera (move it to the outside just to see if it works there).
