Question about Sony Playstation 3 (PS3) Console
When I turn on my PS3 neither the sound nor video work. I was attempting to use an AV cable for sound and an HDMI cable for video, but I couldn't get the system to run. I have tried resetting the video/audio options, but the screen just stays blank. Could using the cables in combination cause this problem?
  • 72 Answers
Its most likely the cables are faulty or you havent placed them into the correct holes. Try using the cables on another playstation 3 console. If the problem remains you need to buy a new set of cables.
Posted on Jul 29, 2009
Hooked up hd cable to ps3 and tv, now have no sound
Be sure to check the cables. You may need to replace them.
Try the cables with another component, if possible.
Also, try using AV cables to verify that it is not the TV and to simply troubleshoot:
To get back to default AV settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    When i plug my hdmi cable into the back of my PS3, it says no input on my TV ?
    you need to connect both the yellow red white cable and the hdmi cable into your ps3 and go the yellow red white av channel
    go to the ps3 settings and change the video settings (ithink) to hdmi and also change the sound to hdmi
    the screen will go blank and then the tv should change to the hdmi av channel if not change to it and accept the changes
    Dec 13, 2009 | Sony Playstation 3 (PS3) Console
    No picture or sound
    Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
    Aug 05, 2009 | Sony Playstation 3 (PS3) Console
    PS3 doesn't work with tv anymore
    did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
    Thx
    Aug 01, 2009 | Sony Playstation 3 (PS3) Console
    My ps3 has no picture or sound...
    if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
    Jan 22, 2009 | Sony Playstation 3 (PS3) Console
    PS3 HDMI & AV outputs not working?!?!?!?
    change the sound output to HDMI? does the sound work on just like a normal tv channel?
    Sep 03, 2008 | Sony Playstation 3 (PS3) Console
    My PS3 recognizes the HDMI input, but when I attempt to change the settings, it won't work
    welcome to fixya
    you have to set it up on the ps3 for the cable
    i had the same problem on the ps3 in settings there is hdmi cable set up make sure there set to hdmi and not to av wire
    Aug 01, 2008 | Sony Playstation 3 (PS3) Console
    PS3 No picture or sound
    When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
    Jun 25, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    100 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
