Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Turn on the power, green light turns on, then it shuts back off
I've got the same issue as another post. I turn the main power on, the green power light turns on, about 2 seconds later, it shuts off. I dont have the remote. Is the only way to power up with the remote after disconnecting the wires, as someone answered?
I have the same problem but I do have a remote and it doesn't seem to make a difference. Has your problem been fixed, and how?
Posted on Aug 16, 2009
Tv turns on and screen flickers on for a second and then turns off, whats the issue?
Sounds like Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
Jul 28, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
When I turn on the TV the green light goes green to red to green to red. If I keep turning it on and off eventually I get a picture. The picture is very dark at first
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 26, 2015 | Akai Televison & Video
TV shuts off automatically
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 30, 2015 | Haier Televison & Video
LC-40le550u no picture... green light on
if powers on and has no video and no audio could be the main board, but first try this :
take a flashlight, turns on the tv and try to "see" the image while light up the flashlight against the screen , if you "see" something you have a bad back light inverter board.
below the posible parts number :
MAIN BOARD : Sharp 9JY0140CTJ05100
POWER SUPPLY/ BACK LIGHT : Sharp 9JY0940CTJ05000
TRY TO LOOK FOR AT :
www.bostonrecycling.net
or ebay
thanks
Oct 09, 2014 | Televison & Video
Picture and sound goes in and out
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 10, 2017 | Sony KDF-E55A20 55 in. LCD Television
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Sony PS3, New power supply issue
There are two different things that i could think of that could be causing this problem. One being the main switch itself. try replacing that. and two the ps3 like almost everything does uses a disk based hdd and if it is dead or shorting out it will instantly turn off so you might want to check that.
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
Can't turn on
sir i guess this is a power supply issue u should change ur the power supply box that u ve inside ur desktop
Aug 13, 2008 | Computers & Internet
Mitsubishi WS-65613 power problem
kindly check the settings.. could be the sleep timer was set ON..
Let me know here again..
`jack
Jun 13, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Inability to turn on plasma screen
You have a power supply fault or one of the drive boards that drive the plasma screen is loading down the power supply. This power supply may be part of the entire main board. Good Luck
Mar 23, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
129 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
