Listed in last post.
SOURCE: I have asked 3 questions in the last 30min but they won't post
I would contact fixya support and let them know that you're being deducted points without actually posting, email them at [email protected] with a description of what's happening and they can direct you better where to go from there.
SOURCE: i have iphone 3g and i cannot dial because keep
connect your iphone to your computer and do a restore
SOURCE: my iphone is disable,i am
Your phone is in recovery mode. You have no choice but to connect it to itunes and restore. Sorry and good luck.
SOURCE: My iphone 4 is disabled,
The only solution for that is to bring your iphone to the nearest dealer near you and have it fix. They have tools to help you.
There are two kinds of backfires, one is produced from the engine air intake and the other is produced from the tail pipe of the exhaust system. The cause for a backfire condition can vary depending on the malfunction of a particular system. Some backfires can be extreme enough to cause damage to related components. Anytime a backfire is observed immediately diagnose and repair as needed. If the engine is running rough it can produce a backfire. A backfire occurs when there is an imbalance in the air to fuel ratio required for your vehicle to operate properly. If the fuel mixture is too lean (not enough fuel) you may have a backfire in the intake manifold gasket, or too rich (too much fuel) you may get a backfire out of the exhaust system. It is important to observe the location of the backfire.
