Question about Dishwashers
Rinse cycle doesn't pump out
My dishwasher usually won't pump out after the rinse cycle (occasionally it does). It works fine through the wash cycle - pumps out OK. If, after it fails on the rinse cycle, I leave it over night THEN put it just on "rinse only," it usually will pump out. The timer in the control unit was replaced by a service person; that made no difference
Nancy
  • 109 Answers
Sounds like the drain pump needs replacing.
Have a serviceman check to prove this is the problem.
Posted on Jul 29, 2009
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Water pump evacuates water but does not pump in the wash or rinse
You assume correct. The control board switches the direction, but if there's a mechanical problem like a bad start capacitor, then it won't run
Jul 29, 2017 | Kelvinator MDB121RF Dishwasher
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
The water is not draining after the rinse cycle
try cleaning your airgap. that's usually the problem when a dishwasher will not drain properly. if that doesn't do it, it's probably pump related. good luck :)
Jul 07, 2009 | Dishwashers
No water going in to dishwasher when rinsing
the pump shouldn't turn on when the rinse cycle is on - it uses only fresh water straight from the water line - after the wash cycle is over - wait 5 seconds, then open the doors and see if there is any rinse coming out of the rinse arms.
If only a little is coming out - check the rinse arm spray jets to see if there is debris caught in them -
if no water is coming out - it could be a faulty rinse solenoid
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Fridgidaire FDB126RBS2 Won't Drain in Rinse Cycle
check the drain pump for foreign object in the pump if nothing is found replace the pump
Apr 25, 2008 | Frigidaire 24 in. FDB126RB Built-in...
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
123 people viewed this question
Top Dishwashers Experts
Owen Barnes
