Question about Thermador PCG364ED Stainless Steel Gas Cooktop
I ordered the contol module for my Thermador range. model PCG364ED. I have unscrewed every screw that I can see on top of the stove to lift up the top so that I can replace my module. I still cannot get the top up. IS there a secret I do not know?
  • mgilmore701 Jul 29, 2009
    Could someone please advise the method for lifting up the top after all the screws have been removed. The initial response is the same as what I could have gotten for free athttp://forum.appliancepartspros.com/oven...
    President:
  • 1,129 Answers
Try looking around the back of the unit, pull it away from the wall to look around the back also there may be some fasteners covered with a stickers, also look from the top of the unit as well.
Posted on Jul 29, 2009
    President:
  • 2,185 Answers
Try this user's:
"I got the other venturi tube off using a spiral bolt extractor. You need a big one, but it worked like a charm (after putting a little liquid wrench in there.) You need a 20mm socket for that silly thing. If you order a replacement ect, you have to take the top off. This is accomplished by taking the venturi tubes out first. You then have all the access you need."
Further, you may want to refer to this forum having similar problem. Hope this helps:
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1140-remove-maintop-thermador-range.html
  • virtualhost
    virtualhost Jul 29, 2009
    You can download Thermadore user guides here:
    http://www.devicemanuals.com/guide/Range...
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
HOW DO I CHANGE THE BURNER SWITCH ON MY RA524
Unplug unit. Remove knobs, if they interfere with lifting the stove top. Lift stove top from front of oven, proceed to inspect dials for damage. Repair or replace as needed.
Aug 22, 2014 | General Electric Cooktops
Thermador gas stove top is clicking when not on
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 21, 2011 | Thermador SGS36GS Gas Cooktop
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 | Cooktops
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
How do you level the stove top
The bottom front of the range has two little legs with hex bottoms. Lift or tilt back the range until you're able to slide a shim (I used a metal ruler) under one of the little legs. Then, unscrew the other leg until it meets the ground. Remove the shim and unscrew the remaining leg until it meets the ground. Check for level and repeat until you get it right. I just did this just 5 minutes ago and if I can do it anyone can.
Jan 10, 2009 | Jenn-Air JED8430 Electric Cooktop
Thermador PCG364ED Stainless Steel Gas Cooktop Logo
70 people viewed this question
Top Thermador Cooktops Experts
Justin Duby
Justin Duby
tom wright
tom wright
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
