SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
SOURCE: Kx-tg1100 registration to anoter base
sorry, it seems that they have to come from the same model base. however, the procedure to reset handset numbers for the 1100 may work for you. there is a 15 digit number on the base unit. try to type that into the 1100 and see if that will register the 1100 to your old base.
SOURCE: I have a Panasonic KX-TCD220E
I had the same problem with KX-TCD220E and BT line. Cured by changing the DSL filter.
