SOURCE: IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
SOURCE: Black & White Picture in different input modes
Can you describe the connections please? I suspect that the DVD +/or WII is outputing component video and you have it connnected to composite video. Please diagram the conenctions.
Thanks,
Dan
SOURCE: I put mu s-video cable in the comp and in the tv
make sure your tv is set to the correct avi or input that your using for the laptop conection to it. hope this helps, normally should just come onto the tv. once the tv is on correct station so to speak.
SOURCE: light comes on but nothing happens
You need to replace the remote more than likely. Thanks for using Fix Ya.
