Question about Kenmore 22422 Top Load Washer
There is a curtain stuck in the agitator how do i remove the curtain
  • 5,911 Answers
It may be necessary to remove the agitator. The following steps explain how:
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
NOTE: Make sure the inner cap (if equipped) is reinstalled correctly. This acts as an air gap to prevent water from getting inside the gearcase (transmission). Do not overtighten the agitator bolt when reinstalling, either. Overtightening can cause damage to the agitator and/or restrict its movement. Tighten until snug.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 29, 2009
    President:
  • 1,136 Answers
Hi, Remove the cap to the agitator and there should be a 7/16" bolt. Remove the bolt and the agitator should lift out. Please let me know if this helped you at all or if I can assist you further.
Thanks
Vic
2 Suggested Answers
  • 36 Answers
SOURCE: several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Posted on Jan 04, 2009
How to replace the curtain switch.
On the curtain at bottom corner is a magnetic switch you have to pry it off it is stuck on with stick-em the one one the curtain has now wire on it and the other part of the switch will that runs back to the control board.
Nov 13, 2014 | Kitchen Appliances - Others
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Mar 18, 2014 | Minolta X-700 35mm SLR Camera
Coin stuck in agitator. how is agitator removed
Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
How do I take out the agitator?
I'm not sure if this is the same as your machine but here is a link to a possible solution:
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
I hope that this solves your problem.
Apr 15, 2009 | Washing Machines
Several pieces of clothing stuck under agitator.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
MAYTAG TOP LOAD WASHER MODEL PAVT244AWW, STRING FROM A CURTAIN IS CAUGHT IN THE AGITATOR. HOW DO I REMOVE AGGITATOR TO GET STRING OUT?
remove the fabric despenser from the top of the agatator, under the despenser is a 1/2 inch bolt, a ratche with a 6 inch extention works well, remove the bolt and the agatator will lift up off the transmission shaft
Apr 12, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
121 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
