My TEAC DV-W24E in a Toshiba Satellite A55-S326 is not working
My TEAC DV-W24E in a Toshiba Satellite A55-S326 is recognized by system but will not read any type of disc. I have uninstalled device, tried MS driver update to no avail.
  • 45 Answers
SOURCE: TEAC DV-W24E Not working
Does the drive appear in the BIOS and the device manager?
Posted on Jan 02, 2008
SOURCE: TEAC DW-224E-B [CD-ROM drive]
Fail could mean a lot of things but those diagnostics (If I remember correctly) look at hardware. If you have a more concise message than just fail (I seem to remember they were) and it points at the cd/dvd first check the connection and if you happen to have an old cd player around try it...if it works and the other does not you have solved the problem. There is more to this but try this first .....FYI...if you were thinking of upgrading to a lightscribe or just wanted to have an extra CD ($10) it may be in your time interest to get one. Much more could mean anything from a bad cable to motherboard problem to....???? This is a start only....let me know....Tango
Posted on Jan 25, 2008
SOURCE: I have a toshiba p25 and the touchpad stopped working
YOU MAY HAVE ACCIDENTALLY HIT THE FN+F9,F10,F11 OR F12 KEYS SIMULTANEOUSLY. TRY HOLDING DOWN THE FN KEY (NEXT TO THE CTRL KEY) AND LOOK FOR THE SYMBOL UNDER YOUR F9, F10 ETC... KEYS AND THAT SHOULD SOLVE YOUR PROBLEM.
Posted on Mar 08, 2008
alexdcd
  • 17 Answers
SOURCE: Toshiba Satellite Pro sp6000 CDRom
You can try this website for the driver search application, i use it every day for the repair of computers, Hope it is of help to you,
http://www.softpedia.com/get/System/System-Miscellaneous/DriverMAGIC.shtml
Posted on Mar 26, 2008
SOURCE: pioneer dvd-rw dvr-k17a
Are these drives you have fitted yourself, or been added as after market drives?
If so you have run in to the odd way Toshiba set their optical drives as master or slave, although this is generally and IDE #1 error.
To fix this you need to solder pin 45 and 47 together.
47 is the key pin here, as it controls whether the drive is in SLAVE or MASTER mode.
grounded, the drive is in MASTER, open, it is in SLAVE.
pin 45 is simply a grounding pin.
So you'll need to open up the drive, turn it over, and put a small blob of solder on the two pins next to each other - 45 and 47.
If they are original drives or used to work then uninstall the drives and the IDE controllers in Device manager and reboot, letting windows redetect and install the hardware. Also try reinstalling the motherboard drivers available from Toshiba's support site.
Posted on Oct 15, 2008
My toshiba laptop satellite A55-S326 wont boot. Only can use the escape key then go into bios but still doesn't boot. Tried my recovery disc & it goes thru the instal but then still goes to a blank...
Your install discs are bad. Please don't shoot the messenger. Call Toshiba for new discs. Here is the number (it took me 30 minutes to find this. Please give me a 4-thumbs-up rating. If you don't, I spent time away from family for free).
(800) 457-7777 (toll-free)
Sep 24, 2011 | Toshiba Satellite A55-S326 Notebook
My toshiba sattellite a55-s326 has a flashing yellow light but won't power up.
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Hope this works
Mar 16, 2011 | Toshiba Satellite A55-S326 Notebook
Support updates does not list my Satellite A55-5326 on there sight. My light is flashing and will not power up.
how many times? 1, 2,3....
maybe battery dead or hardware problems, you can tell-me how many times flash and is a code with 3 digits, like morse
Aug 08, 2010 | Toshiba Satellite A55-S326 Notebook
Did a restore to my A55-S326 with factory restore CD. Now I have no sound.
The drivers all all here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=713844&rpn=PSA50U&modelFilter=A55-S326&selCategory=3&selFamily=1073768663
In the catorgory dropdown choose sound
Also check you device manager Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc Make sure you do not need other drivers
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 26, 2010 | Toshiba Satellite A55-S106 PC Notebook
Replace laptop headphone jack (Toshiba Satellite A55-S326)
It on board so its going to take some really good solder work and a new jack from Radioshack. or the other solution is you can buy a sound card from any best buy, computer store or even online for cheaper then you can to fix that professionally.
Apr 22, 2009 | Toshiba Satellite A55-S326 Notebook
Media Keys don't work after XP reinstall
They should be included with the chipset drivers, you might try looking for a F Lock on your keyboard. Maybe you need to turn it on?
Jan 22, 2009 | Toshiba Satellite A55-S326 Notebook
Toshiba won't start
Hi, what happens when you push the button? Lights, sounds from inside the laptop, anything flash on the screen?
Sep 27, 2007 | Computers & Internet
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
