We can get only the 8 ABC channels. We have just disconnected Foxtel. With Foxtel we could get any number of channels.
SOURCE: TV (RCA model F32705) stuck on one channel
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
SOURCE: Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
