check the foot valve for leaks it at the end of the pipe in the well also if its newer than 30 years there is a cupler where the horizontal pipe meets the vertical on at the well head
It should have a regulating valve to help control the head pressure. It is adjustable to maintain a constant head pressure. The higher the pressure, the more the water should flow to keep the pressure down. Since there is not model number, I can not suggest an exact setting.
water level - pls check incoming water pressure, filter, water level sensor, water valve;
base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
Air/dry/ventilate the unit/system for a couple of days;
reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
F27
OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for
more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump
runs constantly, even if PAUSE/CANCEL is pressed twice and
the display is cleared. Turn off hot and cold water faucets and
unplug the unit before servicing.
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure
switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Hi Error code F 35 means
ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the component
detected by the Steamer Electronic Board. Please check whether the pressure
hose is fixed firmly, and the air trap is not blocked. Make sure the hose is not
plugged. If this doesn't resolve the issue then it is a problem with the water
level pressure switch operation. There could be a blockage in the air dome or
pressure switch hose. The air dome is located on the back of the tub on the
left hand side. If the pressure switch hose and the air dome is clear of any
blockages, then there is an issue with the water level pressure switch,
you would need to replace it. Please post back in case of further assistance.
Hope this helps... Daniel
Seems like 80-85psi is too much supply pressure. I would adjust the pressure switch on your well pump. If it's a 1 horse pump or so- you should be able to go buy a new pressure switch that is pre-set for about $20.
Have the hose pipe running into a bucket/container and use another short length of hose from the pressure washer to **** the water out of the bucket, that way if the bucket is full when you start, any drops in mains pressure wont affect the pressure washer as their should always be a reservoir or water to keep constant pressure.( you may need to prime the suction hose first, just hold the 2 hoses together in the bucket of water with pressure washer on) Any questions ask If this helps please rate me
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit: 1. Make sure that both valves at the water source(s) are turned on all the way. 2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit: 1. Verify Drain pump operation 2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
if you go to the pressure switch inlie (shouldbe within 6 feet of well head) you will ee a rubber plug in th top of it. remove the friction plu an there is an allen bolt under it. adjust pressure with an allen wrench there.
F9=Overflow
Condition
If
the Overflow contact on the pressure switch is Closed for
more than 60 seconds and Overflow condition will occur.
In an Overflow condition, the Door will remain locked, and
the Drain Pump will run constantly, even if PAUSE/CANCEL
is pressed twice and the Display is cleared. Unplug the
unit to service.
Check
the drain hose and make sure it is not plugged or inked.
Check
Wire Harness connectors to the Drain Pump, Pressure Switch,
