Question about Proscan PS52690 52" Rear Projection Television
On and off switch won't respond manually or with remote.
I have a proscan 36'' model number PS35153 when on off switch is pressed light on the front of the set blinks three times and the set makes a sort of crackling noise but won't turn on. Any idea what might be causing this?
  • 616 Answers
Sounds like you have high voltage, I would have to guess the vertical IC has failed. its in the high voltage board and should be done by a qualified tech.
Posted on Aug 30, 2009
Model DR-S2.0. Why doesn't it respond to remotes?
If your receiver does not respond to the original remote, the remote may have failed.
If your receiver does not respond to your Harmony remote, the remote may not have been programmed or may have "forgotten" what to do.
Another possibility is that the infrared receiver has failed
Feb 16, 2016 | Onkyo Audio Players & Recorders
How to turn off closed caption
There will be a button marked "CC" at the keypad of its remote control. Press it once, will make Closed Caption OFF, for an other press it will come again. It is a toggle switch to CC. Gopakumar Gopalan Google
May 07, 2014 | Proscan PS36700 36" TV
Ok, so I got a RCA remote from 1800-remotes for $40.00 that they said is guaranteed to work with the Proscan but do I need to reprogram the remote because it is not working.
Hello
Just try with these four digit codes. Proceedings are given below.
0031 0107 0015 0000 0162 0163
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NOTE: Switch OFF and switch ON the tv with its front panel power control switch [NOT BY REMOTE CONTROL HANSET] before each try.
Dec 24, 2010 | Proscan PS32500 32" TV
Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get it to shut off, remote will not respond & there is no reset button. Help please?
The problem is most likely the switches on the front panel. If the manual buttons are constantly shorting out, then the TV will try to respond to those buttons, and not the remote. Manual buttons almost always override a remote. Check the front panel for shorts, or if the buttons are constantly depressed.
Dec 13, 2009 | Toshiba 36A43 36" TV
New TV
You can call PROSCAN at their customer support telephone number. 1-888-977-6722. You can also use their customer support website. www.oncorpus.com. go to the customer support section, tell them the model of you television and the problem you are having with the remote control.They should be able to help you. I hope this information helps you with your problem.
Mar 20, 2009 | Proscan 32LA30Q Television
How do I get my ProScan on channel 73
You can manually input 073 with the remote when the remote is in tv mode and on one of the channels that you do get.
this link will download the ProScan 32LA30Q owners manual with
complete instructions on setting up the tv and programing channels.
Thanks for using Fix Ya, please take the time to give this solution a Fix Ya ratting.
clarkco
Feb 07, 2009 | Proscan 32LA30Q Television
Need user manual
Here's the link to all Proscan TV Manuals =>
http://oncorpus.com/down/down.htm
Here's the link to your Proscan model#42LA45H 42" lcd tv =>
http://www.oncorpus.com/down/ENG/42LA45H%20English%20UM.pdf
Dec 26, 2008 | Proscan PS36700 36" TV
PROSCAN PS35130
I got an old (1995) 36" proscan without a manual, and it's been a pain to get it working. Nice enough TV once you do, though.
The weirdest thing is that S-video shows on channel 91, and the AutoProgram function won't find it. That's right; they just randomly picked 91, and you're stuck with it.
Pressing Menu on the front brings up the menu. Pressing it again cycles through choices, and the plus and minus buttons to the left of it activate the choices.
Good luck finding any more info; hope this helps
Sep 04, 2008 | Proscan PS36500 36" TV
HOW TO OPERATE PROSCAN REMOTE MODEL CRK76DBL1..
I still have not figured out how to program the exact code in the crk76DBL1.
However, I did figure out how to use the code search for the TV
1) Turn on the component you want to control (TV, VCR, DVD)
2) Press and hold BOTH the component button on the remote and the On-Off button
3) The On-Off button remains lit. Now press Play (The On-Off button will blink)
4) If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
5) When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
6) To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
I hope everyone finds this helpful and saves people time and frustration.
Feb 22, 2008 | RCA DIRECTV Satellite Remote Control
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Televison & Video Logo
102 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
