Question about Jensen Car Audio & Video
VM92113 Stuck in camera mode
So I got my new deck installed today and it wont go out of Camera mode. I can still hear the radio but i cant see what station im on the only thing that appears on the LCD is the word ''CAMERA'' when i flip out the monitor it still does nothing the screen is blue and blank with the words ''no camera signal'' going across it. I tried inserting a Cd, nothing, a DVD, nothing, MP3 player, again nothing.......I also tried using an SD card with the adapter and still nothing happened. why wont it work?
  • 216 Answers
SOURCE: 9" FLIP DOWN TFT LCD CAR MONITOR DVD OVERHEAD TV
No problem.
The size will not be the same.
Ask for the size, you wants the same or a larger size.
atdlee@netzero.com
Posted on Mar 08, 2008
jango2
  • 38 Answers
SOURCE: Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Posted on Mar 09, 2008
SOURCE: memory card stuck in camera slot
No need for pliers! I was able to eject the memory card by sliding a packing knife along the edge of the memory card. The blade was very thin, narrow, and long. I'm not sure if a regular box cutting knife blade would do. I've been able to eject the memory card with ease about a dozen times using this method.
Since I can't eject the SD card on the go, I use the USB cable to download images from the camera. Glad to know I can remove this when absolutely necessary, but sure wish I could remove anytime I'd like.
Jason
Posted on May 11, 2008
  • 47 Answers
SOURCE: jvc in car cd player kd-g162
REMOVE THE FACE PLATE YOU SHOULD SEE A SMALL OPENING THIS IS THE RESET BUTTON PRESS IT GENTLY WITH A PEN THAT SHOULD SOLVE YOUR PROBLEM
Posted on May 13, 2008
  • 47 Answers
SOURCE: my dvd player screen
WHAT BRAND IS IT?
Mytape deck is stuck and i cant put a cassette in it. How do i fix it?
Getting that radio out of the dash is a chore. Taking the radio itself apart is worse. Have a shop give you an estimate.
Feb 18, 2016 | 1997 Buick Century
Why is my My Jensen VM9214 stuck on camera mode
Check your wires, theres a wire for the reverse if your going to use a back up camera, if not do not connect it, you may have had it connected through a speaker wire, if so then thats your issue and once you wire it up right it wont do that any more, had the same issue and thats what fixed it hope this helps
Dec 09, 2012 | Jensen Vm9214 Car Video Player
Kodak c433 stuck in connect mode
You may have to connect to a computer then disconnect it from the computer safely(click on safe removal icon in the tray)?
Feb 15, 2012 | Kodak EasyShare C433 Digital Camera
A200 faulty selector switch
Same thing happened mine. Take out battery and leave camera for a few weeks until internal cell goes flat. Switch to "stills" mode and put battery back in. You will need to reset the date and time. LEAVE SWITCH IN "STILLS" mode for ever more.
Dec 31, 2011 | Konica Minolta DiMAGE A200 Digital Camera
Lens wont go in
I had the same problem, my workaround was:
1. turn on the camera, you will hear some beeping as the lens tries to raise from the body of the camera
2. wait until the camera turns off
3. pull the lens gently until you hear a 'click'
4. turn on the camera again, it will work normally (hopefully)
Another interesting thing, you can switch on the camera in "play mode" only, by holding down the play button on the back while pressing the power button. In that way, the lens will not raise and you can copy the images.
May 24, 2010 | Polaroid i735 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
Wont take pictures
First of all you should take a look to the little "guide" that I posted to the "stuck lenses" problem for LUMIX. But in your case the camera is very different, so: first thing you should do is (hoping that its just a simple stuck problem, try moving the zoom gently doing circular movements and then more gently in and out with the camera on. VERY GENTLY!!! if that does not help, try disassembling the camera, the structure is similar to the one I described in the text, although its parts are smaller and more delicate. Every LUMIX camera cheaper that $ 1500 seems to have this kind of problems... REMEMBER TO BE REALLY CAREFUL or your zoom will say good bye.
Feb 27, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
My hp photosmart m525 camara is stuck in dock mode
I've also had similar problems with a HP M425--periodically it seems to get stuck in "docking mode". Where I plug in the USB on the side is clean, but I forgot about the place to plug in a different type of cord on the bottom. Cleaning these contacts with a pin solved the problem.
Feb 25, 2008 | HP Photosmart M525 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Camera stuck on auto mode
have you tried removing the batterypack for 10 - 12 hours and again reinsert and check.
Apr 07, 2007 | Nikon D70 Digital Camera with 18-70mm Lens
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
