Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
I have a kemore elite fridge wont get cold little cool air but not getting cold frezer is fine
  • Kenmore Master
  • 4,655 Answers
The problem is most likely the defrost timer. I don't have your model number so I am going by what I can find about a Kenmore Elite.
The defrost timer is located most times insid the fresh food compartment and behind theconteol panel. Usually there is a hole that you can put a flathead screwdriver through and slowly turn the timer clockwise until the refrigerator compressor and fans stop. Let it stay like this for about 25 minuites until the compressor restarts. During this time the refrigerator should be in defrost. Open the freezer and listen for crackling and sizzling noise caused by defrost. If the compressor does not restart turn again clockwise and this will restart. If you nee the defrost timer here is a link below.
482493 Defrost Timer
Let me know if this don't work and we will need to go mto step 2, Thanks, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Posted on Jul 29, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Frozen coils anny one ???
defrost fridge replace theromostat and timer
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
My refrigerator is not getting cold frezer work fine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | Refrigerators
Temp in the refrige wont stay cold. frezer is fine. model name is rs2545sh
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 25, 2010 | Samsung Refrigerators
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
Our frezzer is working fine but the fridge isnt
the return air ducts are frozen, not allowing cool air up to the fridge
unplug unit overnight and let defrost,you can speed up the defrost time by using a blowdryer in the freezer compartment
Jan 16, 2010 | Samsung Refrigerators
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge does not get very cold,compressor comes on, frezer is cold
check to fan inside unit air not transferring from freezer to fridge fan uses cold air from freezer to cool fridge check that fan is working usually can feel but may have to push button on door and hold if no fan remove cover and check for ice on blockage if none have fan serviced or replaced -if fan is working properly, same area is a damper that my be blocked or frozen good luck and thank u for using fixya
Oct 14, 2009 | GE Refrigerators
It can be the defrost timer,defrost element or defrost thermostat or a blocked vent into the fridge
Aug 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Fridge wont cool but frezer is fine
looks like you have a problem with the damper control. try to locate the sensor for the damper control and relocate it, if still not cold, replace it.
May 04, 2009 | Freezers
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
326 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
