Question about Kenmore Elite 45986 Front Load Washer
I have kenmore elite smartwash quietpac9. The washer keeps stopping soon after starting and F 11 appears to be flashing. Any thoughts on what that means?
What might be causing the intermittent F-11 codes on a Kenmore Smartwash front loading washer?
f11 error is communication error.most likely bad solder joints in ccu or mcu.
May 08, 2017 | Kenmore Washing Machines
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
He5tsteam kenmore elite smartwash quietpak9 keeps flashing F35
Analog sensor failure. Replace that puppy using this VIDEO GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 18, 2012 | Kenmore HE5t Steam 4.0 cu. ft. Front-Load...
He4t kenmore elite smartwash quietpak9. keeps flashing F2?
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Mar 02, 2010 | Washing Machines
So i put a load of clothes in my kenmore elite smartwasher and right after i start the washer the load stops and i get this message ''sud'', what does it mean?
IS IT AN OASIS? JUST RINSE THE SYSTEM OUT WITH WATER. YOU MIGHT BE USING THE WRONG DETERGENT. THOSE MACHINES REQUIRE "HE" DETERGENT.
Jan 14, 2010 | Kenmore Washing Machines
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Smartwash control locked light went on after I finished a load. Now no buttons work. How do I unlock the controls?
Just remember, the instructions are printed near the button. This features locks and unlocks the control panel as a designed safety feature to prevent small children from manipulating the controls. In addition, if you get error codes, or the panel starts flashing or freezes up, sometimes these errors can be erroneous. Unplugging the unit for 30 minutes will reset the Central Control Unit (CCU). This is the main "brain" of the washer. Any error code following a computer reset, is usually a genuine problem. If you ever have questions about this washer in the future, please keep me in mind. Congrats on getting it working again!
Mar 03, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
102 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
