Question about Garmin StreetPilot C330 GPS Receiver
Our gps c330will only power up for a few seconds and then the screen goes black, have tryed the reset doesn't help. can you help? not to happy with the garmin have had less then a year.
    Brigadier General:
  • 4,090 Answers
The battery is float it either needs a good 5 hours recharge on AC charger or a total replacement.
If the batter is good then the other possibility is that the maps are corrupted. As you have had it less than 12 months i suggest treturning it for a warranty check repair
Posted on Jul 29, 2009
GPS screen goes black
Try to keep the memory as empty as poss to avoid this in the future. Clear old data on a regular basis that is not longer needed.
Jun 08, 2012 | Garmin Nuvi 760 Car GPS Receiver
My navigon 2100 doesnt work after the update. help
I own a navigon 2100 as well. Very nice device and you can install the 5100 software and the 7100 maps and points of interest. gpspassions.com is the best resource for 2100 help.
Try this:
Hard Reset Procedure - if the PNA is on, press the Power button until the unit goes off. Press again and hold the button down - the screen will come on and after a few seconds go off again. Press the Power button again and the screen will come back. If you get the opening "music", you know the Hard reset was successful.
If you leave the memory card out and keep the unit powered on, you will after a few 10's of seconds go into the Demo mode. When you reinsert the SD card a soft reset will occur (equivalent to pressing the recessed button on the left hand side) and the unit will initialize into whatever the SD card tells it to (see below).
source:
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=101685
Apr 13, 2011 | Navigon 2100 Portable GPS Receiver
Screen has frozen, can't turn it off or move anything, just not working.
There are a few things you can try to resolve this:
  1. Hold down the power button for up to 15 seconds to reset the unit.
  2. If that doesn't work, you'll want to try changing the power connection to the unit. If you don't have it plugged in to the cradle or the usb cable, plug it in. If it is plugged in, try unplugging it.
In the event it stays frozen, eventually the battery will drain. When the screen goes blank, you can then plug the unit in and recharge it. Let it charge for at least 30 minutes and then try to power on the unit.
Mar 03, 2011 | Tomtom ONE GPS Receiver
My New Garmin Nuvi 1400 will not turn on - it just gets to the screen "Loading maps" and then the screen goes black. I have tried the suggested holding down the power button for 10 seconds, but nothing...
My Garmin Nuvi 1490 was on for five or six hours driving then the screen went dark and now unit will not turn on or light up screen at all ? ANY HELP OUT THERE ?
Feb 09, 2010 | Garmin nuvi 1490T GPS Receiver
How to turn off TomTom gps one 130
Gps 130 is supposed to hybernate only. It is almost impossible to turn it completely off.
Nov 12, 2009 | Tomtom ONE 130 GPS Receiver
Locks up after a few seconds/have to kill power to reset
This may help. Mine has the GPS antenna build into the bracket at the back. I removed the bracket and the unit did not go into the error screen and the sounder worked fine. The GPS would not locate but it has not antenna attached so DOH!! I have orderd a new antenna with the BNC connector and will post if that fixes the problem. At this point I'm guessing its a blow GPS antenna.
Dave
Oct 12, 2008 | Garmin GPSMAP 168 Sounder GPS Receiver
Black screen
This problem has happened to me before turn the gps unit over and clean off the gold colored conductors on the bottom take a paper clip and touch the 1st and 4th pins together this resets the unit be sure it is the 1st and 4th pins on the opposite side of the little power connector though.
Jun 26, 2008 | Mitac Mio C320 Car GPS Receiver
Nokia n95 screen problems
Try a hard reset on the device. Pull the battery out whle the device is on. Then put back in.
If that doesn;t work, try reloading the OS.
Jun 02, 2008 | Nokia N95 Cellular Phone
GPSMAP 235 Sounder
Some 235s had a problem with the contrast setting. When the contrast is set to full the screen turns black.
When you turn on the GPS and the screen goes black, try tapping the left arrow on the track pad a few times. You should see the screen start to lighten. If that doesn't work, tap the power key and try tapping the left arrow a few times.
May 17, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
176 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
