Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Washer shuts off automatically then turns back on.
  • 99 Answers
It sounds like it could be something as easy as the electrical connection behind the washer not being tight enough. Hope this helps.
Posted on Jul 29, 2009
I have a LG top loading washer. Cold water will not shut off, making it so washer will not shut off. Water still runs after we unplugged the washer.
Close the cold water valve behind the washer, then try a reset. If that doesnt work, the timer may need to be replaced. Depending on your skill level, you could do it yourself.
To reset the washing machine:
  1. Press POWER to turn the washer off.
  2. Unplug the washer from the power outlet. ...
  3. With the power disabled to the washer, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in, or turn the circuit breaker back on.
Nov 28, 2016 | LG Washing Machines
Automatic detergent dispenser
I would consult a washing machine engineer for the answerer as there are limitless reasons for your problem its cheapest in the long run of frustration eric
Dec 18, 2017 | Daewoo DWD-WD1352RC 4.5 cu. ft Capacity...
It shut down automatically and won't turn on after that.
The computer/laptop is heated up too much on the same place. You have to wait about 5-10 minutes if it automatically closes, so it it gets cold.
Dec 29, 2011 | Sony VAIO Y Series Notebook VPCY118GXBI
Dryer will not shut off.
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | GE Spacemaker Washer and Dryer Electric...
I have a M157305J North Star pressure washer. The
The thermostat in the control is sticking... by turning it a bit you get it to release and kick back on...
You need to replace the control...
Heatman101
Mar 03, 2010 | Garden
Water not flowing
There could be a few reasons for this problem.It is probably a faulty out of balance micro switch,Located under the main motor controller board in the head section.Bypass the switch to test.The next thing to do would be to check the diaphram in the inlet solonoids.Take off the coils & with pointy nose plyers unscrew the centre of the solonoids and check for purferated diaphrams.If there faulty replace the diaphrams or the complete solonoids.Hope this helps Cheers.
Oct 31, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine shuts off before cycle is finished now it will not last one min. on before it shuts off...what to do?
We have a front-loading LG washer. Today, I took a look at it when it was beginning the spin cycle because it sounded a bit different. I noticed that it was beginning to spin and would stop because [I believe] it was detecting a strong off-balance. It would then try to spin in the opposite direction and the same happened. After two more attempts, it automatically shut off with no warning nor error. We set the washer to wash and spin again and I began to work on balancing it. After adjusting the feet and waiting for the spin cycle again, it continued successfully because of the reduced off-balance. I'm not sure if there are other reasons that would cause the washer to turn off. This is the only one I have come across so far.
Oct 22, 2009 | LG WM1812C Front Load Washer
Everytime it search for a coverage it automatically shuts off
hi friend,
First make sure it's not set to automatically shut off. Go to Options...Auto On/Off and make sure Weekday and Weekend are set to Disabled.
Mine doesn't shut off automatically. However, sometimes when I shut the phone and then turn it back on, the mobile network is not on and I have to go to "manage connections" and turn it on. I checked the options and both weekday and weekend are disabled
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | RIM BlackBerry 7230
Hotpoint washer , top load
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Jan 01, 2008 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
43 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
