SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
SOURCE: How do I change my whirlpool oven back to Farenheit instead of celcius...
its in your manual, did not give model number so i looked up anyone. if this does not work you can enter your model number here for a copy of user manual
http://shared.whirlpoolcorp.com/product_literature/search.jsp
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit.
SOURCE: convert temp control from celcius to farenheit
Yo can do it the long way:
°F to °C
Deduct 32, then multiply by 5, then divide by 9
°C to °F
Multiply by 9, then divide by 5, then add 32
Or you can do it the easy way and go to:
http://www.wbuf.noaa.gov/tempfc.htm and use the converter.
Thanks for using Fixya.
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
SOURCE: I have a goodman mini
To change from Cecilius to Fahrenheit on the remote control, hold both the + and the - simultaneously and this will enable you to toggle between C and F. You will need to do this each time you change your batteries.
