Question about Olympus VN-3100PC Digital Voice Recorder
My VN-3100 DVR died and new batteries did not work. Suggestions?
    Problem Solver:
  • 18 Answers
BUY NEW ONEEE.
Posted on Aug 04, 2009
I just removed the batteries of my olympus vn-3100- shows ERR
you should replace your old battories put the new battries in it. carefuly.
Apr 26, 2010 | Olympus VN-3100PC Digital Voice Recorder
Brand new battery keep's on dieing??new coil maybe,dunno,won't start.
Charge the battery and refit to the bike, start the engine and check that the charging system is working ok. Set multimeter to DC and check that it is charging between 12.5 - 14.8volts at a steady rate when revs increased steadily. If the voltage is not increasing or very erratic then it is a good indication that the regulator/rectifier is at fault. If the battery is charging well above the 14.8 then the battery is at fault.
Apr 01, 2010 | 1994 kawasaki VN 750 Vulcan
Jamo dvr 50 buzzing/crackle from speakers after repair
Guess it would be cheaper to buy the DVR-60 , og DVR-70. I recall having seen good publicity on the dvr-60, but guess it would be hard to get your hands on that one. I have found the dvr-70 at the price of aprox. 200£. If you change the "motherboard", it will probebly brake down again, en just as expencive. I believe the cabinet is overheating do to lack of aircirculation, when you open it, there is no dust to be found at all...
Feb 15, 2010 | Jamo DVR-50 System
My Olympus VN-3100 voice recorder has suddenly stopped working! When I switch it on it flashes CHK for a couple of minutes then says ERR
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory (ERR means memory error). Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model.
Dec 16, 2009 | Olympus VN-3100PC Digital Voice Recorder
Recently I purchased the Dragon Naturally Speaking 10. It works very well on straight dictation. However, I cannot seem to load my recordings from the Olympus VN-3100 PC unto the Dragon Speaking. Any...
There are several "flavours" of DNS 10, and only the Preferred and Professional versions will allow you to submit a pre-recorded sound for recognition (from the Sound menu). If you have a lower version such as the Standard, you will need to upgrade to at least Preferred.
I hope this helps
Jun 26, 2009 | Olympus VN-3100PC Digital Voice Recorder
I need instaii cd to digital voice recorder olimpus VN-3100
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Apr 06, 2009 | Olympus VN-240 Digital Voice Recorder
Nikon COOLPIX 3100 Digital Camera
I WOULD SUSPECT THAT THERE IS SOMETHING WRONG ON THIS NEW DOOR THAT THE BATTERIES ARE NOT MAKING GOOD CONTACT WITH THE DOOR AND THEREFORE NOT SUPPLYING POWER TO THE CAMERA. IF IT WORKED BEFORE THE DOOR WAS REPLACED, THERE MUST BE SOMETHING AT THAT POINT. I WOULD LOOK THERE FOR PROPER PRESSURE ON THE BATTERY OR BATTERIES.
Oct 31, 2008 | Nikon COOLPIX Cameras
Vn-3100 non pc
I beleive that recorder is mono. You have to use an adapter for stereo headsets or listen on one side of the head set.
Accessories are available at olympus.com
Jun 30, 2008 | Olympus VN-3100PC Digital Voice Recorder
Error message
I had the same problem with my Olympus VN-5000. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again. I hope this solution works for your model!
May 26, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-3100PC Digital Voice Recorder Logo
48 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
