SOURCE: how do you thread a singer 6215c sewing machine
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines.
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
SOURCE: How do I install a tension knob on a brother VX710
Call Brother at 1-877-276-8437, DO NOT INSTALL ANYTHING THAT WILL VOID YOUR WARRANTY. As for tension, read your manual, it will advise you.
SOURCE: sewing Machine Manual Singer modle 6215C
Singer has the manual for the 6215 sewing machines on their site for sale or download. The direct link for the downloadable version is http://www.singerco.com/uploads/download/1316_6215.pdf . (Note: Singer does not use the letter suffix in their manuals; one manual will apply to the entire set of machines.)
I hope this helps.
