Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Refridgerator side not cooling. No air movement.
Refridgerator side not cooling. No air movement. vent is clear
IF THE CONDENSATE DRAIN OPENING IN THE PAN (JUST UNDER THE COIL) IS CLOGGED OR THE CONDENSATE DRAIN LINE IS CLOGGED THE CONDENSATE HAS NO WHERE TO GO AND JUST BUILDS UP IN THE PAN. WITH THE COIL SO CLOSE THE BUILD UP WILL FREEZE USUALLY FREEZING THE FAN BLADES IN THE ICE ALSO.
DEFROST THE PAN, CLEAR THE CLOG AND MAKE SURE THE DRAIN IS CLEAR BY POURING SOME WATER DOWN THE DRAIN AND SEE IF IT MAKES IT TO THE DRIP PAN UNDERNEATH THE REFRIGERATOR.
Posted on Aug 11, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Posted on Jul 29, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My 04 toyota rav 4 when the heater is on blows hot air out the center , right floor and right upper vents and cold air out the left floor vent and upper left vent. heater temp. control works, pos
Check your ducting and hoses going to the left side. Maybe one came loose.
Maybe a door towards left of heater case is not opening. Watch the cables for proper movement when operated. Maybe you can spot the problem. Good luck.
Nov 24, 2011 | Toyota Highlander Cars & Trucks
Refridgerator side by side not getting cold
When we had this happen, the air vent between the freezer and fridge side was blocked with ice and wasn't letting the cold air come thru from the freezer. That's what cools the fridge. Our vent was up at the top between the two.
Jul 17, 2011 | Maytag Refrigerators
Refridgerator is not cooling. I hear the fan but there is no air flow
Ok when you say you hear the fan and no air flow, am I to understrand if you put your hands in front of the vents in your freezer no air comes out ?
The noise you are probably hearing is the compressor motor running (a humming sound) - you may have a bad evap fan - you will need to have your system checked and check the evaporator fan motor - if this is not working there will not be any cooling and air flow. they might also want to check your control board.
Aug 23, 2009 | Whirlpool GS2SHEXN Side by Side...
AC only on the drivers side
you are low on refridgerant
Jun 26, 2009 | 2003 Buick LeSabre
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
Ed27dsxdw01 side by side fridge
I had this "problem" for a little while. Thought I was gonna trash the fridge and start over anew. Turned out I had a bag of greens sitting up along the top left side of the fridge that was blocking the vent where the air from the freezer side blows in to cool the fridge side. Clear off the top left side of your shelf to start with (would be good if they included this "tip" in the owner's manual).
Aug 15, 2008 | Whirlpool ED2FHEXN Side by Side...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
341 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
