Question about Kyocera Mita FS-1920 Laser Printer
Lines on the page
I am getting a few lines which runs on the page..
I've tried cleaning the printer from top to bottom and inside out.
Is there any way to get rid of those lines??
  • piyopiyo Nov 26, 2007
    I've done all I can and the problem is still there.
    I might have a dud drum.....
    Thanks for helping kemo anyway
  • Anonymous May 30, 2008
    I have about the same issue, the one vertical line will be on the left margin, I have replaced all parts of the printer except the fuser unit. The roller on the left side is damaged, how do I remove the fuser roller and replace it with my new one.
  • 56 Answers
Hi,i will do this: Remove toner,then remove developer unit.Try to clean magnet roller on developer unit with dry cloth, if see lines on roller.Pull out paper transport unit(green handle ) and clean transfer roler and vacuum it.Then ,when is paper transport and developer unit out, remove drum unit(open door on the left side on the printer and pull out drum). Remove Corona from drum unit.Remove and clean grid,corona inside and corona vire.
Check fuser and drum for scratches.
Posted on Nov 23, 2007
  • Kemal Muderiz Nov 23, 2007
    Also go to menu,others,service,drum and press enter/ok key twice.Refreshing will take about 3 minutes.
Why am I getting vertical Yellow lines on my printing?
It sounds like the laser drum is damaged and not collecting toner correctly. First try cleaning the paper path with laser cleaning paper. If that doesn't sort the problem replace the drums.
Aug 09, 2014 | Ricoh Aficio SP C811DN-DL Printer
My documents have black lines running through them. whats the problem?
  1. Print a few more pages to see if the problem corrects itself.
  2. Clean the inside of the printer and run a cleaning page to clean the fuser.
  3. Replace the print cartridge.
  4. The printer might be due for maintenance. Check this by printing a copy of the supplies status page. If maintenance is due, order and install the printer maintenance kit.
    For an illustration of the 'lines' defect and information on other print-quality issues. please refer here.
Dec 14, 2010 | HP LaserJet 4250dtn Printer
Hi, I have a black line that runs from top to bottom of the page when scanning, faxing and copying. How do I fix this issue?
the blcak line that runs from top to bottom is due to a dirty misaligned print a full printer maintenance on your printer/scanner . Once the heads and rollers get clean and the printer is aligned, it should get rid of any black streaks or lines. I own a Brother Printer/scanner and it did the same thing to me, as soon as I ran maintenance on fixed the black straks and lines I had on my prints.
Jun 18, 2010 | Brother MFC-9420CN All-In-One Laser...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Printer problem
Does the line appear while copying or printing ?
To isolate the issue try to print a self test page :
1. Press and hold the Cancel button and then press the Start Copy Color button.
2. Release both buttons. The self-test page prints.
If you see lines on the test page then the issue is with the cartridge or cartridge contacts. Clean the cartridge and cartridge contacts inside the printer.
rRemove both the cartridges. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth. Gently wipe the contacts, from the top to the bottom.
Reinsert the cartridge and print. If the issue issue persists replace cartridge(s).
If you do not see lines on the test page. Place the same test page on the scanner glass and make a color copy. If the lines are on the copied Image the issue is with the scanner glass.
clean the scanner glass :
Clean the glass and scanner backing
  1. Turn off the all-in-one.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the all-in-one.
  4. Raise the lid.
  5. Clean the glass with a soft dry cloth, or a sponge slightly moistened with non-abrasive glass cleaner or water. CAUTION: Do not use abrasives, acetone, benzene, or carbon tetrachloride on the glass; they can damage it. Do not place or spray liquid directly on the glass; the liquid might seep under the glass and damage the device.
  6. Dry the glass with a chamois, cellulose sponge or soft cotton cloth to prevent spotting.
  7. Clean the white scanner backing with a soft dry cloth or sponge slightly moistened with water, and allow it to dry.
Try a blank copy
  1. Plug the power cord back into the wall outlet.
  2. Plug the power cord into the all-in-one.
  3. Turn the power on.
  4. Close the lid; do not place any paper on the glass.
  5. Load paper in the paper tray.
  6. Do either of the following:
    • Press Start Copy Black to start a black-and-white copy job.
    • Press Start Copy Color to start a color copy job.
  7. If the output is a full/half-black page, or has vertical black lines, the product needs service or contact HP for in warranty replacement.
Thank you .
Dec 20, 2007 | HP Photosmart C3180 All-In-One InkJet...
White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Nov 10, 2007 | Lexmark X5470 All-In-One InkJet Printer
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Black lines down page
It must be the black pcu , the cleaning blade picks up dirt and causes these lines , it can also be the black developer giving you trouble , if you want be very carefull aand strip the pcu open you will see the lines only on the inside and not from outside , then you will know if it is developer or the cleaning blade
Oct 24, 2007 | Ricoh CL4000DN Laser Printer
If the line is solid from top to bottom of the page, the problem can be in different parts of the printer. Try a different toner cartridge if you have an extra one.
Jul 25, 2007 | Konica Minolta PagePro 1350W Laser Printer
Kyocera Mita FS-1920 Laser Printer Logo
294 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
