Question about Hotpoint HSS25GFP Side by Side Refrigerator
Frig and freeze work fine!! But an ordor started and is staying!!
Done it all!! Cleaned ,used odor absorbers and still no luck. The food tastes odd the ice and the icecream all have that same gross taste. took out all food, and threw it away plus emptyed all ice. Now, the new ice and anything we put in there smells and tastes so odd and gross.... Help help help. Frig. not even that old. And I donot save leftovers or keep onions in frig. I'm so confused. Seems to be coming from the freezer and maybe icemaker. But I cant tell the smell slams u in the face when u open the door.
  • 1,543 Answers
Most likely some raw meat juice leaked into a spot you can not see or get to. The defrost heater area and / or the defrost drain are the most likely suspects. If you can diss-assemble enough to get to these to clean, you stand a good chance of conquering your odor problem. Additionally, there is one odor absorber that has worked rather well for me, but I don't remember the exact name,.... but I'll post it in an additional comment tomorrow.
Posted on Jul 29, 2009
  • Carl Schulzetenberg
    Carl Schulzetenberg Jul 29, 2009
    Get the 1/2 once liquid size of Odors Away . It is available at Do It Best hardware stores (Item # 621854), on line at hardwarestuff.doitbest.com , or I'm sure at other places as well. You use just a few drops and it eliminates most odors by neutralizing the odor molecules, not just covering up the odor. It comes with a guarantee : If ODORS AWAY does not solve your odor problem, mail unused portion with proof of purchase ....... for refund.
    This is the stuff you want to try.
How do I clean my ice maker?
Curious, does your refrigerator have a water dispenser? How does water taste from it? Your ref. has one water supply for both ice and water. Changing filter was a good start but if it's been over a month, there's something else going on. I would look and see behind your ref. and look at the water line. I've run across a bad plastic tube that causes a bad taste. If you have a plastic one, change it out with a new one. Also, ice absorbs food odors from both the freezer section and refrigerator sections, so check your fridge for bad food. Bell green peppers are the worst, they'll leave a metallic taste. Good luck!
Sep 18, 2015 | Refrigerators
Model 795.76202.901 bottom freezer with in-drawer ice maker has smelly ice.
You will have to conceder that ice cubes are like sponges. They will absorb odors from food or items within the unit. If the water entering the unit has no odor, the smells are from the food or liner within the unit. Here is a science experiment for you, try fresh coffee grounds, use this in both sections in an open container and the coffee smell will over power the smells but will absorb in the ice cubes. This will prove this issue. Consider using a deodorizer in the unit to absorb odors from uncovered foods and placed in both section within the unit. I hope this helps. Good Luck
Sep 26, 2014 | Refrigerators
Bad tasting ice/water/food
Have you put a few boxes of baking soda in the fridge to absorb the pungent odors? Do that.
Jul 07, 2017 | Kenmore Side by Side Refrigerator
Chemical smell in frig permeating food taste. Is it dangerous
First remove all the food and produce and thoroughly clean the fridge with disinfecting wipes, then put a couple of boxes of Arm And Hammer Baking soda in the fridge to absorb the odors. And no it is not dangerous in my opinion. I have smelled fridge odors that would gag a maget
Apr 25, 2017 | Refrigerators
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
Bad Odor in Whirlpool Conquest Refrigerator
put boxes of baking soda opened in the frig. The baking soda will absorb th odor.
Sep 21, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore elite odor
If something spoiled in there, especially if it sat inside for awhile. you may be out of luck. The disagreeable odor may be permanently installed in the insualtion inside the mouldings. Replace it; otherwise..try washing inside thoroughly with soap and water or simple green. Then baking soda and water and leave doors open until completely dry. Then B-soda on a plate in the box.
Apr 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
307 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
