Question about Garden
My string trimmer will not start
My 2 cycle string trimmer will not start and if it does it stalls or runs rough. I have pulled and cleaned the plug and drained the fuel (I left the fuel in the tank last winter, my bad) I cleaned the air filter and checked the spark inhibitor screen which was fine. I put it all back together and put fresh fuel in the tank, pumped the primer bulb and it still won't start.
    Problem Solver:
  • 9 Answers
Possible solutions:
-Kill switch is shorted out-check the wire and connections.
-Buy a new plug.
-Primer bulb needs to be replaced.
-Fuel filter needs to be replaced, and it's located inside the gas tank so it's a bit tricky to replace.
-Try starting it without the air filter attached.
Is it possible an incorrect mix of gas/oil was used (or straight gas) which in turn ruined the motor?
Posted on Jul 29, 2009
Looks like oil and fuel is leaking or blowing from exhaust.
John - Husqvarna makes really good power equipment that seldom offers trouble. The unit you are talking about is a 2 cycle system, meaning you mix oil and gas together in lieu of having an oil sump at the bottom of the engine like 4 cycle motors have. First question, did you mix a bottle of One Mix 2 cycle oil to a gallon of regular gas to start off using your machine? If you did, then I would think your unit is badly flooded, which happens a lot with 2 cycle equipment. Try taking out the spark plug and see if the spark plug looks wet from too much fuel. If it is, leave the spark plug out for a day or so to allow the cylinder head to vent the gas fumes. Replace the wet spark plug with a new one and try to start the unit again. Here's a tip: If you do flood a 2 cycle piece of equipment (trimmer, chainsaw, blower, etc.) again, make sure the choke is off and hold the throttle trigger wide open. Pull the started cord several times until the unit starts to run. Keep holding the throttle wide open until it clears itself out. Remember, you run the equipment, it does not run you :-)
Aug 01, 2016 | Husqvarna 223L 24.5cc 2-Cycle Straight...
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Trimmer wont run
David check the spark plug first and then the air filter. If both of these are clean and the spark plug is sparking put some fuel into the block.see if it runs then.
Oct 02, 2013 | Cub Cadet ST228 17" 27cc 2-Cycle Gas...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
String trimmer stalls
More information would be great, Does it have a good spark and compression.? Is fuel getting into the cylinder.? Are fuel lines in good order and no holes.? Does it idle or stall when revved.?
May 23, 2012 | Husqvarna 28cc 2-Cycle Curved-Shaft Gas...
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Hard to start and won't keep running. Fuel on spark plug.
your carburetor needs to be cleaned. after that it should run good. its just not pumping enough fuel to it.
Apr 06, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Troy-bilt TBP6040 4-cycle stalls out after about 10 minutes. Started doing this the 2nd time I used it. After it stalls out it will not start until it completely cools off. Fresh fuel in it. Arrestor...
I have the same model from Troy-Bilt. I have only had it about 4 or 5 months. Mine has started using a LOT of oil. I noticed a significant increase in temperature compared to my old Husqvarna 2 cycle. Mine does not completely stall, but it does start to sputter when it gets hot. I am going to take mine back to Lowe's where I bought it. So far I am VERY unhappy with the TBP6040.
Aug 24, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
May 17, 2009 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
