Question about Refrigerators
Fan and I presume condenser are running constantly for the last 48 hours. Temperature is creeping up in the refrigerator and the bottom freezer is above freezing. Cleaned the coils underneath, which gave us a brief improvement, but temp is still in the refrigerator heading up to the high 40's.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
You have a coolant leak or a failing compressor
time to call the service tech out br you cook somthing else
Posted on Jul 29, 2009
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
My figidaire freezer fans runs almost all the time
Your problem could be as simple as dirty condenser coils or a burned out condenser fan. These components are on the bottom of the refrigerator and removing a couple of panels should give you access to them. Clean dust and dirt off the coils and check to see if the bottom fan is running when the refrigerator is running.
You'd be surprised how often this simple fix will get you back up and running. Dirty coils make the refrigerant system VERY inefficient, sometimes to the point that the refrigerator has to run almost constantly to acheive the desire temperatures inside the refrigerator.
Mar 16, 2013 | Refrigerators
Hi, I have a GE side by side GSS23LSTA refrigerator The last few days it has been running constantly. The refrigerator side temperature is fine at 35 degrees, but the freezer temp is staying at around 12...
Hi Mark and welcome to FixYa, I am Kelly
Touch the front of the unit where the doors close and feel if it is very very warm to the touch. If it is very warm to the touch... here are the prime suspects:
1. condenser coils covered in lint
2. condenser fan not running or running slow.
An easy way to determine if there is a condenser fan or coil fan problem is to simply direct a floor fan at the base if the refrigerator. If it cools down substantially in an hour.... there is a problem with the coils being clogged or the condenser fan not running. If that makes no difference... before opening the back of the unit... inspect the back wall of the freezer compartment for any signs of ice build up. If you see ice-build up.... unplug the unit.. remove freezer contents and direct that fan into the freezer compartment for just over 2 hours. Then return the unit to normal service.... If the temps come down to normal... for 2 - 3 days then start creeping up again... you have an automatic defrosting problem.
Forgot to mention... make sure the evaporator fan is running at full speed.
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Kemore refrigerator seem to be running constantly. It is only 4 years old. Out of 5 hours it has been running 2 hours and 43 minutes, at different time intervals. Temperature in freezer and...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Control lights ( temperature readings etc ) are consistently blinking on and off, accompanied with a beeping sound
Main control board is over
temperature. Look for blocked condenser air flow or inoperative condenser fan motor.
Refrigerator over 48°F or
freezer over 15°F for 3 hours.
Run diagnostics and test operation of all components.
Both thermistors failed.
Run diagnostics and test thermistors and thermistor leads.
No feedback from evaporator fan
motor. Run diagnostics and test fan motor and/or wiring. The manual is HERE
Jan 29, 2010 | KitchenAid KSSC48QMS Side by Side...
Just purchased a 2 yrold Kenmore French Dr/Freezer on the bottom frig How long until it starts making ice. I've had it plugged in for 28 hours now. It's hardly cold inside. AHH! Help please.
From initial start-up you should be at operating temperature in 24-48 hours depending on the ambient temperature. Both controls should be on the mid setting. Make sure the condenser fan underneath is operating and the coils should be very warm. If not there may be a problem in the sealed system.
Eric
Oct 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Long run time between defrost cycles
You have a broken defrost part. Either the heater, t-stat or timer. The longer you let it go without repairing it, the more parts is take out.
Aug 13, 2009 | Kenmore 56176
Refrigerator is not getting COLD
clean the coils on the back of the fridge and make sure the condenser fan is free and running normally. that is the fan at the back of the unit on the bottom where the compressor is. if it cant ge rid of the heat, it wont cool. also make sure the the fan that supplys the cold from the freezer to the fridge is working.
Jul 21, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
My refrigerator has unusually high temp... 77 degrees and counting.. nothing unusual in the last 36 hours. may have started to creep up yesterday. the freezer seems to be working fine and nothing is...
The most common cause of inefficient refrigeration is dirty condenser coils or a defective condenser fan (the fan at the bottom of the refrigerator that pulls air across the coils).
Try the free fix first... Clean the coils. And while you've got the panel off, see if the fan's running.
Hope this helps.
Jun 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
