Question about Haier BC112G Wine Cooler
My unit cannot maintain the correct temperature. its too cold. the display shows 'LL'
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Sounds like the thermostat is pooched
Posted on Jul 29, 2009
Just put new batteries in both units but can't get the oudoor temp to show - what have ee done wrong?
Replacement has to be done in a certain order.
  • Remove all batteries
  • Install batteries in outdoor unit. Allow time for unit to initialize and begin transmitting temp.
  • Install batteries in indoor unit. You should see outdoor temperature displayed.
You may find that the outdoor temperature is not transmitted in very cold weather. Right now it is below freezing and my indoor unit is showing - - for outdoor temperature.
Dec 13, 2016 | Measuring Tools & Sensors
Why does the external unit go between extracting hot and cold air without any setting changes?.
if you have your air conditioning on an "automatic mode"
You set the temperature and the unit will decide what it has to do to achieve this temperature, ie heat or cool, the unit will the switch back and forth to try and maintain rhe set point temperature, this is totally normal,
Feb 01, 2016 | Heating & Cooling
If my thermostat sensor is faulty, how can I verify that is the issue? Is that part expensive?
if the thermostat is faulty it will show up as two things
the car will overheat within 5 minutes of start up (10 minutes max) as it will be stuck closed and prevent coolant circulation
and second it will be stuck open which will be seen as taking a long time to reach normal operating temp which will be a long time if ever in cold weather and very low ambient temperatures
you call it as a thermostat sensor where it is a coolant temperature sensor which is a different unit
the sensor in this case reads the engine coolant temp and reports to the ECM so that correct air /fuel ratio can be maintained under all conditions
It also reports that the coolant temperature is too high and so the ECM turns on the fan/s to cool the radiator
They cost from around $20.00 to $80.00 ud depending on make of car , generic or genuine
Dec 16, 2015 | Cars & Trucks
How do I get it to display outside temperature?
Usually, batteries have to be installed in the remote unit first, followed by house unit. Allow time for the remote unit to begin sending data to the house unit, then you should see it displayed.
May 15, 2015 | Measuring Tools & Sensors
Radio Shack 63-1090 indoor/outdoor temperature unit. Won't give outdoor readings. Temps are cold, -5F but it always worked before. Put in new batteries in the inside and outside units, wiped outdoor sensor...
According to instructions for similar systems, you have to replace batteries in the outdoor unit first, then the indoor unit and wait 10 minutes without pressing any buttons for the indoor unit to begin displaying the outdoor temperature.
Dec 31, 2013 | Heating & Cooling
Wont start when cold
Your Temperature Sensor is bad or has failed. This sensor monitors engine operating temperatures. The signals needed for the ECU to determine whether the engine is cold, warm or hot, then it will set the system to operate correctly for that temperature. Ex. When the engine is cold (first start up) it will supply the fuel system with more fuel for the air/fuel ratio for a richer mixture to start and maintain correct idle.
Dec 05, 2013 | 2000 Volkswagen Beetle
In-Line heater does not operate
an inline heater does not heat the water it only maintains the water temperature that is in the bath. try filling the bath with the required water temperature and see if the heater maintains that temperature. good luck
Dec 04, 2013 | Maax Home
Not maintaining temp.
1:-Watch for leaks in the gasket. The door seal is one of the most important parts of the unit when it comes to maintaining the proper temperature. If there are any holes or gaps or spaces where it has torn or warped, your refrigerator will constantly be leaking cold air out into your kitchen. It will have to work ten times as hard to maintain the right temperature.
2:-use defroster once in a week.
3:- check the gas(it may be empty).
Mar 01, 2011 | Refrigerators
Freezer not staying cold
thermistor has worned out so please change the thernistor then you ll find the temperature gets maintained in 0 degrees......
Sep 10, 2008 | GE PTS25LHP Top Freezer Refrigerator
Haier BC112G Wine Cooler Logo
457 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
