Question about Epson Stylus Pro 10600 InkJet Printer
For some reason, the yellow is no longer printing on my Epson Stylus Pro 10000. I've swapped out the cartridge with another printer and it works fine. Help...
    President:
  • 2,185 Answers
If the yellow is no longer printing, print head nozzle must have clogged. It can be due to using non-epson ink Cartridges or even due to aging equipment.
You can try getting a print head cleaning solution and clean it, but you must do it with great care because the nozzles are very delicate. You can get a cotton ear bud, dip it in distilled water, and clean the gold contacts. Don't forget to switch the power off before doing this. Make sure everything is dry before trying to print again.
Posted on Jul 29, 2009
Epson 10000 not printing cyan and black
Take the inks out and put them back in. May have got unseated. Check for foreign objects which may have jammed the heads.
Jul 08, 2016 | Epson...
Tip
Epson Stylus pro 10000 Vista x64 Compatible? YES
Use the driver for the next model up: Epson stylus pro 16000.  A 64 bit driver is available for XPx64 on Epson site:  http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=19156&prodoid=22966689&infoType=Downloads&platform=All Install Printer Driver v5.50 in Vista x64.  The 10000 will print 100%, just like in XP with its own drivers.  Any problems?  I would happy to help you save the time I spent before finding that out.
on Apr 05, 2009 | Epson Stylus Pro 10000 InkJet Printer
Tip
Epson Stylus pro Vista x64 Compatible? YES
Just purchased an Epson Stylus Pro 10000 Archival Ink. Nosel check looks good with solid lines, however prints are very light. Ran clean multiple times. Printer came with existing ink and I don't know if...
Old ink loses some of its intensity after about 8 months.
heat/light seems to destroy some of the depth in the ink's shade. i would be completely replacing the cartridges with fresh ones. Constant cleaning uses up so much ink and the casettes will need replacing too often. This raises the cost of your prints.
May 09, 2010 | Epson Stylus Pro 10000CF InkJet Printer
Epson 10000 Doesn't print full image.
Hi, Go in the printer section under Control panel. Right click Epson 10000 icon, than Properties. Go to Ports. Click the port it is using. Configure port. Protocol must be LPR Queue name under LPR settings: type: print (small letters) Check LPR counting enabled box.
Try. It should work.
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
EPSON STYLUS PHOTO RX685
try with chip reset for all you cartridge
Jun 29, 2009 | Epson Stylus Pro 10000 InkJet Printer
Does it work with mac OS X 10.5.6
Check this page on the Epson website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14366&prodoid=4742585&infoType=Downloads&platform=Macintosh Good luck!
Apr 25, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson 10000 printer colors not printing
I am gonna gusess there is a break (or poor connection) in one of the lines in the flexable cable that feeds power to the print heads. You might try checking the continuity of each line.
Sep 12, 2008 | Epson Stylus Pro 10000 InkJet Printer
EPSON STYLUS PRO 10000
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
Aug 30, 2008 | Epson Stylus Pro 10600 InkJet Printer
Epson error code 0104
00000104 Auto print head optimization system is all the manual says. No solution given.
Apr 01, 2008 | Epson Stylus Pro 10000 InkJet Printer
Epson Stylus Pro 10600 InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
