My cd dropped in my Dell. the door opens but no cd comes out. What can I do?
  • 99 Answers
I don't know what kind of Dell you have, but if it is a desktop or a laptop you should be able to take out the disk drive itself and then open up the disk drive or at least shake the cd out while it is open.
Posted on Jul 29, 2009
    President:
  • 2,666 Answers
Am I right in saying that you put a cd into the drive but it hasn't come out?
It cant drop anywhere most likely it wasn't placed correctly in the cut out in the drawer and is stuck.
You now have 2 options
Option 1 With the drawer open carefully feel in the centre top of the drive and see if you can feel the cd and gently pull it out. This is not to stop damage to the cd but to the drive accept the cd will be ruined.
Option 2 Remove the drive and carefully take the top cover off and remove the cd.
Either way the cd is a bin job but you may with care salvage the drive. The cd has to be in there as there is no way out through the back.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Unplug computer with cd open flip computer upside down and shake with cd open 1/2 way
it should dislodge
failing that open computer remove cd drive and shake the chit out of that bad boy buy remember the more you shake the more you scratch the disk
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Posted on Feb 22, 2013
Open disc drive door
There's a button in the center of the CD tray you must push to get it open with the notebook powered on. If you need to open the door without power on then push a paper clip in the tiny hole on the CD door to release it.
Feb 21, 2014 | Dell INSPIRON 15 Notebook
I have a Dell Inspiron 1525 with a cd in disk drive. The door will open but disk won't come out. What do I need to do to remove it?
The CD is loose in the drive. You need to remove the CD drive from the computer and then remove the metal case off the drive then you can remove the CD. Put the metal case back on the drive and install the CD drive back into the computer.
Mar 21, 2013 | Dell Inspiron 1525 Laptop
Dell cd drive door won't open
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
Stuck cd inside dell xps laptop's cd drive. How to remove outside?
I had the same issue with my Dell XPS 15z, after looking every where to get instruction to get the CD out. I decided to call Dell Tech Support and it did work.
1. Turn off the laptop
2. Turn on the laptop and press F2 several times until the setup menu come up
3. Then press the eject botton from the keybord, the Cd should come up.
Good luck
Mar 13, 2011 | Dell Studio 15 Laptop
The CD rom door on my DELL dimension C521 won't open
Have you tried to manually open the door by sticking a paper clip (unbent) in the small hole on the front bezel of the CD-ROM drive?
Oct 07, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
CD ROM
If the drive door sticks after you have used the paper clip to open it, look under the tray at the drive teeth (if any). Apply a liberalm coating of general purpose grease to the rwo inches of teeth at the end of the drive tray nearest you and close the drive door again. Open and close a few times to see if the door is now free. This worked for me on my Dell Inspiron 3100. Try it.
Jun 24, 2008 | Dell Computers & Internet
CD/DVD
see care fully on the cd/dvd door, there must be a very narrow hole. This is an emergency hole to open the door.
  1. Make shutdown your Lap.
  2. Take a long niddle or hard wire.
  3. Push it gently inside the hole.
  4. It will strick inside, then push with slightly more force and you will notice that door is openning. Just push more till you can pull out CD/DVD tray by hand.
Thanks
Iqbal
Apr 28, 2008 | Dell Open Box 8300-6SZ0X41 P4-2.8G 256M...
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
