Question about Yamaha Water Sport
2000 yamaha xl 700 will not run above 3000-4000
2000 yamaha xl 700 will not run above 3000-4000 rpms in water but will hit the rev limter out of water
  • 7 Answers
SOURCE: i have a 2000 nissan maxima and the problem that i
Idle air control valves short out all the time on these models. You can ohm the motor to check it, but the down side to a shorted iac valve is that it shorts out the ecm if not repaired quickly. when the valve shorts, 12 volts is supplied directly to the ecm and burns the circuit board. The other option is the air flow meter, this is also a very common problem but typically a p0171/p0174 would be stored in self diag.
Posted on Jun 22, 2009
  • 124 Answers
SOURCE: 2000 grand caravan won't go above 70 mph. high rpms
First I need to ask is it a 4 speed or a 3 speed transmission. If it's a 4 speed when driving down the road pull it from drive to third gear. You shpuld hear the engine speed up if it does not then that means you have on 4th gear and you will have to take it to a transmission shop. If it's a 3 speed then just count the shift points if all 3 gears are present then drive down the road and see if the van goes into tcc. When you mean the rpms are high how high are they.
Posted on Jul 15, 2009
  • 5522 Answers
SOURCE: when the boat is in
The last comment you made about the hose cuffs and running good- Was that in gear or neutral? If you are using the boats throttle lever there is a cam lever for the choke which limits the throttle. It may be out of sync in the control box. If you have operating cables disconnect them at the engine and see what range of motion you have in the motor itself. Then hook up the controls and see if the cables prevent the motor from opening the carbs.
Posted on Aug 01, 2009
  • 10 Answers
SOURCE: 95 2.3l ranger: When engine is cool, it will miss
an ignition coil and/or wires seem to cause the most trouble when cold or damp. Sounds like you have a bad coil or wire(s). Spray down ignition coil and wires with water (in a spray bottle). If the engine reacts you may be onto something. I have also seen carbon tracking on the spark plug that can cause this. Cracked coil housings are common on a lot of Ford ignition systems
Posted on Aug 05, 2009
bazzz7071
  • 338 Answers
SOURCE: i have a 1986 yamaha virago 700 that wont run properly
2 things need to be done first start your bike get a can of wd40 after your bike is warm and running spray around the carb jointsall 4 of them if your engine changes rpms up or down you have a intake leak ether your carb joint gaskets or o-rings need replacing or your carb joints are old and need replacing. at this point wont hurt to have you carbs cleaned also
Posted on May 03, 2010
2008 Grizzly 450. Starts and idles fine but at about 10 mph why does it start to cut out like a rev limiter?
2011 grizzly 450 reverse rev limiter - Yamaha Grizzly ATV Forum
www.grizzlycentral.com > ... > Grizzly Engine & Transmission
Mar 11, 2012 - 9 posts
This is a discussion on 2011 grizzly 450 reverse rev limiter within the ... is for earlier model years like 2008. thanks for welcoming to the site :) rev limiter - Yamaha Grizzly ATV Forum
May 23, 2009
Grizzly 700 Reverse rev-limiter Override Mod - Page 3 ...
May 21, 2009
Hitting rev limited/ slow speed.... - Yamaha Grizzly ...
May 20, 2009
reverse rev limiter - override witch bypass - Yamaha ...
Oct 22, 2008
More results from www.grizzlycentral.com
Rev Limiter - GrizzlyOwners.Com Yamaha Grizzly Forums
www.grizzlyowners.com > Grizzly 660 > Modifications
Old 06-30-2008, 10:43 AM Thread Starter. modrak .... jasson450r is offline ... hey guys! how do you do this rev limiter mod on a 06 660 griz? i'm interested in ...
How to bypass reverse switch Grizzly 700(speed limiter ...
? 1:03
https://www.youtube.com/watch?v=l8nn5Z4cuN0
Dec 25, 2015 | Yamaha Motorcycles
Yamaha Wave Raider 1994 wont rev past 2900 rpms
check all cylinders sparking ,working by carefully removing plug caps one at a time to see if you can hear a change in sound and check compressions 100psi or more on all !!
Jun 09, 2013 | WSM 1994-1997 Yamaha Wave Raider 700 Cc...
Yamaha xl 800 won't hit top speed and won't rev out to max rpm
Did the Impeller Pitch Change? Pitch will change the Max RPM, Are you Pulling harder out of the Hole than you did prior? You may have traded Torque for Top End
Apr 02, 2013 | Yamaha Xl Xlt 1200 Gp1200 800 Limited Air...
I have a 1986 yamaha virago 700 that wont run properly
May 03, 2010 | 1985 Yamaha XJ 700 X Maxim
Need help
It my be your rev limter coming on
Nov 10, 2009 | Honda Cars & Trucks
2000 WAVERUNNER 1200 ENGINE REVS RPMS GO UP BUT IT WONT GO
I have a 1999 yamaha xl 1200 that has just had a new motor put in y the dealer. It revs but will not go foward or rev.
Aug 07, 2009 | Yamaha 12V Air Pump
4wheeler will not rev up
Your jets are plugged rebuild the carb, soak the jets in carb cleaner overnight
Apr 04, 2009 | 2003 Yamaha YZ 250
Water Sport Logo
98 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
