Question about Pro-Fit Pro.Fit Ns 70 00 Infiniti Qx4 /Nissan Pathfinder 01 Up
Driver side door will not lock or unlock with remote all other doors will lock and unlock
    Problem Solver:
  • 9 Answers
Most likely the metal rod that attaches the lock with the actuator has come lose. You will have to take the door panel off to check it out.
Posted on Jul 29, 2009
Driver side door will not lock/unlock with the remote, but the other doors will.
no you needs a new lock actuator on that door its about $90 installed,
all the locks are on same circuit . sorry about the bad news :(
May 01, 2016 | 2003 Hyundai Sonata
The drivers side cook lock does not lock or unlock using the remote. The other door do respond to the remote. What is the cause and solution?
Hi Charles
The drivers side door gets the most use
Check the actuator wiring coming through the door hinge
If it works from the key then the Power to the door is OK & the key switch is ok. Must be trigger wire from wireless device receiver!
Good Luck
Hyundai Door Lock Actuator eBay
Hyundai Entourage Alarms Remote Car Starters Keyless Entry Locks
Jul 08, 2015 | 2008 Hyundai Entourage
How do I get my driver side door to unlock and lock. Remote opens and locks all other doors
The lock actuator is apparently bad in the driver's door or there is a broken wire to the actuator.
Feb 22, 2015 | Cars & Trucks
Driver side door locking with remote but will not unlock, if i unlock it with key then remote will unlock all other door, if all doors are locked remote will not unlock the car. Once i manually unlock...
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
Sep 01, 2012 | 2003 Mitsubishi Galant
Driver side door doesn't lock or unlock with the remote. The rest of the doors work fine.
Does the Driver side door lock and unlock from the lock switch inside? If not then you have a bad motor or bad connection to the lock/unlock motor inside the door.
Jan 08, 2010 | 2004 Toyota Camry
Driver side lock
the solenoid may be weak, or it can be lubed. you will need to remove the door panel and see how it works, and try to lube it, or see if there is any binding.
Oct 12, 2009 | 1999 Honda Civic
Drivers Door Lock Problem
Press the passenger side door lock button. if the driver side door unlocks now but wont unlock when you hit the driver side door lock button, it is usually a network communication problem with the B CAN or a faulty Body Control Module.
May 01, 2009 | Honda Accord Cars & Trucks
2005 honda accord doors will not open with remote
need an actuator for the driver door need more info go to collisionrepairadvice.com for how to do it yourself
Apr 11, 2009 | 1998 Honda Accord
Pro-Fit Pro.Fit Ns 70 00 Infiniti Qx4 /Nissan Pathfinder 01 Up Logo
343 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
