SOURCE: blows ignition fuse when key is turned on
Look for a grounded wire on the ignition switch or a break in the wiring leading to the fuse. Wiring system on motorcycles are a close system with only the battery being grounded to the frame. Any loose connections or breaks in the wires that will allow the current to jump to the frame with cause you tons of fun.
SOURCE: I have an eztrak john deere 445... quits.
The vent in your gas cap is plugged, it's a very small hole right in the center.
SOURCE: John Deere 445 lawn tractor is leaking coolant
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
