Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinking Gren Light on 52 Inch DLP
We had a power outage and when the power came back on the blinking green light appeared. I tried to reset it and can't get it to reset. Need help on what to do.
    Sniper:
  • 53 Answers
Is this a WD-52525? If so, and the timer light doesn't stop blinking, you have a problem in your electrical chassis.
In essence, you can do 1 of 2 things:
1. If the 8 capacitors on the DM and FMT circuit boards are vented, you can slug through disassembling the entire electrical chassis, dig out the 2 boards, re-solder in some new caps, reassemble the darn thing and pray to the gods.
I've done it a few times on some sets; it's a **** shoot on whether it works or not.
2. You can send the chassis off to Mits for a rebuild. Expect to shell out about $400-$500 for the rebuild. And, if you are squeamish about taking out the chassis, expect another $200-$300 for someone to take it out, box it up and put it back in.
Oh, and expect to wait anywhere from 4-8 weeks for it to be returned to you, as well.
It's a shame, I know. I wish there was better news.
Remember, this only applies if you have a DLP (those 52-525's are notorious for this), and the timer light never goes off.
Posted on Aug 01, 2009
  • 135 Answers
This is not a lamp problem. The indication for the lamp is the orange light. The green light will eventualy stop blinking but it may take several attempts of unpluging it and plugging it back in and waiting. The power supply was getting weak or was damaged by the sudden power outage. There are some capacitors that are overworked in the power supply on all Mitsubishi sets Rear projection and DLP and everyone I have ever seen has needed replacement. If you cant do the repairs yourself, it will need to go to a shop. Good luck.
Posted on Jul 31, 2009
  • 167 Answers
It most likely burned out the Lamp. DLP TV's need time to cool the Lamp after power is turned off.The fan will run for a few minutes after a normal power off condition from the front control button or the remote.When you lost power, the lamp was still hot and was unable to cool down.You can replace the Lamp yourself.Go to www.dlplamps.com
Posted on Jul 30, 2009
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a WD-52525 set that the green light kept blinking after a power outage. The reset button never worked. I unplugged the set for 30 seconds and re-plugged it back in. The light began blinking between...
Bad digital/power module. Contact Mitsubishi, they may cover part of repair, I am serious. If not, have a an authorized servicer send module to Mitsubishi for rebuild program. The only economical solution.
Jan 18, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinking green
you need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
May 23, 2009 | Mitsubishi WD-52725 52". Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
