Kitchen Ranges Logo
T
Teresa White Posted on Oct 16, 2017
Frigidaire gallery model #LGEF3045KFK glass top began beeping and flashing f11. Unplugged it for 30 minutes, replugged and the stove works fine but it shows 5d and the stove wont work.
Wasnt using oven when the error went off. using front right cook top eye
3 Related Answers
Anonymous
  • 76 Answers
  • Posted on Jan 01, 2009
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Anonymous
  • 750 Answers
  • Posted on Jan 31, 2009
SOURCE: stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Anonymous
  • Posted on Aug 07, 2010
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Reset circuit breaker to fix F11 or just plug stove in
How we solve toshiba washing machine E3 error?
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
10helpful
2answers
Morison,
A Broken Stove
whats the entire model number?? and you cracked the main top glass assy??? ill look up tha part for you, not a teribly hard job, but depending on glass may be expensive
Stove beeping
FRIGIDAIRE
Code
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
