Question about Gateway GT4010 (RBGT4010) PC Desktop
My problem is the same, it happens when i'm in fullscreen.
When i'm playing a fullscreen game, my power button will go from green to orange. Then the screen goes black and says Entering Power Save Mode. My music and audio is still playing though, but my screen won't turn back on.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Go in and fix the power settings under screen saver disable sleep mode on drives and monitor disable sleep mode on every thing just use blank screen instead
bes fix 4 ya
Posted on Jul 29, 2009
Lamp cut off, power light(green) flashing, ready light (orange) off
deffo the bulb life. not a cheap fix as bulbs are very expensive. reset the unit by holding a few buttons.mine resets by holding 2 buttons while off. google master reset for your model and you might get some more user time from the bulb. change bulb asap tho
Mar 08, 2014 | Dukane ImagePro 8039B LCD Projector...
Tip
How to reset waste ink counter of canon ip 4000?
the procedure to reset waste ink counter of canon ip 4000 printer is as follows,read it carefully step by step:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons.
The LED lights in green to indicate that a function is selectable.) .
2) While holding the Power button, release the Resume/Cancel button. (DO NOT
release the Power button.) .
3) While holding the Power button, press the Resume/Cancel button 2 times, and
then release both the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in
orange and green, starting with orange.) .
4) When the LED lights in green, press the Resume/Cancel button 4 times. (Each
alternately in orange and green, starting with orange.) .
5) Press the Power button. The LED lights in green, and the reset is performed.
(When the operation completes, the printer returns to the
menu selection mode automatically.) .
6) Press the power button to exit service mode.
Note:- if you accidentally press the Resume/Cancel button more than 4 times in
step 4 then just press the Resume/Cancel button at least 10
times and the printer will be returned to step 4 automatically.
BTW the other functions that are available at step 4 are -
press 0 times = power off
press 1 time = Service Test Print
press 2 times = EEPROM information print
press 3 times = EEPROM initialisation
press 5 times = Destination settings (country information, do not play with
this)
press 6 times = Printhead Deep Cleaning
press 7,8 or 9 times = not used in servicing so do not play with these.
press 10 times or more = return to menu (step 4) .
This will help.thanks.
on Mar 10, 2010 | Office Equipment & Supplies
It wont charge it blinks three times then stops
Hi,Okay, well, I don't want to be a shill for Apple (I mean, heck, I had to buy my Shuffle, so it's not like they're sponsoring this in any way! :-) so let's talk about the color sequences and what they mean.
First off, there are a number of different functions that are denoted by different color sequences, so flashing green might mean one thing when you're listening to music, and something else entirely when it's plugged in and charging or syncing with your PC.
The primary functions are powering on, charging, syncing, and general feedback. Let's look at each.
When you turn on your ipod shuffle, the light will indicate your current charge level:
green = 30-100% charge, you're good to cruise
orange = 10-30% charge, low, but still good for a short workout
red = less than 10% charge, time to plug it in
no light = too late, you've run out of juice
If you see an alternating pattern of green-orange-orange then your Shuffle's crashed or otherwise needs to be restored. Needless to say, that's not a good thing, but probably easy to fix when you hook it up to your PC or Mac.
When you're charging up your shuffle, there are three possible light states:
orange = charging
green = fully charged, unplug whenever you're ready to go
flashing orange = busy, either syncing or in use as a remote disk
When you're playing some music, you can see visual feedback on what's happening and what state you're in:
Press play and
solid green = you're playing music
flashing green = you're in pause mode
Press and hold play and
green-orange-orange-orange = you've disabled your buttons
orange-green-green-green = you've reenabled your buttons
That's bound to be one where people panic and fear that they've broken their shuffles, I bet. If your buttons aren't working at all on your Apple iPod Shuffle 2nd Gen, then press and hold your Play button to see what light sequence you're given. This is also shown by the Shuffle flashing orange when you push a button too.
If your player flashes alternating green and orange, you have no music in the shuffle. This can be because it's fresh out of the box, or because, well, something's happened and the music has vanished. Either way, time to sync with your iTunes library.
If you're seeing a flashing red sequence, you're just about out of battery and just need to plug it in so it can charge up.
Finally, Apple has some good tech notes on the new Shuffle too that you might want to check out if you're still a bit baffled by this tiny engineering wonder: Understanding status light behavior, Shuffle Second Gen, Frequently Asked Questions and iPod Shuffle Support Overview.
Feb 17, 2011 | Apple iPod shuffle Second Gen. Silver (1...
We were playing a game and the tv screen went black then we ejected the game and the wii console will not shut off and now it wont play a game or nothind then we tried to unhook it and the light stayed...
Power light is green or orange - TV screen is blank
    If the power light is green or orange and your screen remains blank, follow these steps.
    1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
    2. Make sure your Wii console has the most current Wii system menu. Download the latest update (how to), and then test your Wii console to determine if the problem has been resolved.
    If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired.
Jan 27, 2011 | Nintendo Wii Console
My NDS lite power cannot be turned on and turns off randomly
The problem is that your son dropped it. This damages both the inside and outside of the DS. I would suggest contacting your nearest video game store to see if they can fix it.
Aug 04, 2009 | Nintendo DS Lite Console
Waste ink absorber is almont full. How do i empty this
Hi
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Cheers
Jul 16, 2009 | Canon i80 InkJet Printer
Mrs
The key means youre psp is locked, swith the power button to the middle (when its down, the psp is locked) if its not down, theres a problem with your power button and it needs to be replaced.
Feb 04, 2009 | Sony PlayStation Portable (PSP) Console
I think the X-box does not Sync
Try this method :
Check if your XBOX 360's Power Supply has an orange or green light. If it is RED, then unplug the power supply from the socket.
If it is orange or green, then try and unplug the Power Supply from the Back of your XBOX, wait 1 minute. Then plug it back in.
If that doesn't work then call 1-800-4MY-XBOX and speak to a XBOX Representative.
Jan 04, 2009 | Microsoft Xbox 360 Console
USB guitar for 360 won't play correct notes
try the slots in the front, i never use the one on the back of the system to play games,
my rockband guitar works find in gh3
Dec 02, 2008 | Activision Guitar Hero III: Legends of...
Full screen
What games do you play?
In some internet games you can press F11 for full screen.
Though in most games you have to go through their menu's to get full screen.
In windows the default keystroke for fullscreen in Alt, Enter pressed together.
Though that is not a guarantee either.
Generally how to get full-screen is different from game to game in some sort of settings menu.
For instance I play Last Chaos online and it is automatically full-screen.
When I played runescape online I had to select full-screen at the log in screen.
Sep 17, 2008 | HP Pavilion dv6000z Notebook
Gateway GT4010 (RBGT4010) PC Desktop Logo
129 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
