Question about Niko OTP-3211W 32 in. LCD Television
Niko Screen and channel problem
Ever once in a while the screen turns green in certain areas and everytime i turn the tv off it forgets its channels
Re: Niko Screen and channel problem
Fortunately, I have not had the fuzzy green screen problem in quite awile, and since getting the Dish, I have not had to worry about channel memory loss. I am thinking about turning this one into a computer this even possible... and getting a bigger tv for the front room, HD of course.
Posted on Sep 25, 2008
0 characters
3 Points
I might of hit the wrong button when i was trying to switch inputs... The screen asked for 4 number password but i never had set one. So i just turn the tv off and on but now my tv shows vizio on the...
Dear Sir:
Follow this step:
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
  • 2 Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
  • God bless you
    May 14, 2012 | Flat Panel Televisions
    Every time we turn the tv on we have to search for channels. The set up screen comes up
    after you tune your channel once, you have to save it. otherwise they would check everytime
    Jan 12, 2012 | Philips Flat Panel Televisions
    I have a Grundig XENTIA 82 FLAT MFW 82-430/8 TV, everytime i turn it on i get a blue screen & the child lock nb to fill in, so i have to type the nb 7038580 to watch tv... how can i cancel this koz...
    If this is happening on all the channels I think you will need a total reset. If so open menu and check the settings for child lock when you manually tune. An option is to reset the channels once again after the lock is opened. Choose a new channel scan to reset the memory. However if the lock seems to be only on specified channels you can open the settings of the channel and unlock on the menu.
    Oct 16, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
    I have a flat screen and Dish Network for my cable. I switched the "source" to watch a dvd, and when I switched it back to channel 3 I have a blue screen. cable (dish network) is on and working....
    It all depends on how your dish cable is connected to your television. The possibilities I can think of would be by composite cables (not HD)--these cables are the yellow red and white combo. It could also be component--the video cables are the blue, green and red. The other possibility is a single HDMI cable which looks like a rectangle and delivers both the video and the sound from the cable source to the T.V. as one cord. Depending on which of these you are using to output the signal from the cable box to the T.V. will determine which "source" you should select when trying to watch tv. Hope this helps!
    Aug 25, 2011 | Niko Flat Panel Televisions
    I got a sony bravia kdl46nx800 led tv and for some reason, there is a green line on the right edge of the screen on certain HD channels and not on regular channels when i watch the shows. it is a common...
    Hi, I can't say I've ever seen that happen with that TV before so I'd say it definitely isn't common. I'm pretty sure it's the signal from the HD channels, I'd suggest talking to your cable service provider.
    May 14, 2011 | Sony BRAVIA NX800 KDL46NX800 46 in. HDTV
    I am not getting picture on my TV it stic on only one channel we are chengiong channel but same sound is comming also we are getting a blue coloured K on right hand side of TV
    That blue K means you are in the service mode. Unplug your set and wait 30 seconds. Then at the same time you plug it back in, you need to be holding the volume down button and the input button.
    The TV should turn back and the blue K should turn pink. Once this happens, press the volume and channel down button at the same time. A menu should come on the screen. With your remote, press the up arrow to reach the nest page. The first option should say INIT. Arrow to the right and hit enter. In a few seconds your screen should turn green and say success. Unplug the TV and wait 30 seconds. Plug the set back in and turn on your TV. You can then set your set back the way you want.
    May 04, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
    Vizio 32lcd turns itself off on certain station
    Do a full channel scan again. It should solve that problem.
    Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
    How do you connect a...
    If you use RCA cables from the dvd player set your tv to (line) or if your useing coaux cable try ch.3 or ch.4 your dvd might have a switch for 3or4
    Dec 24, 2008 | Niko OTP-3211W 32 in. LCD Television
    Wharfedale 37 inch lcd tv
    sounds like screen control is set too high
    Sep 02, 2007 | Flat Panel Televisions
    Niko OTP-3211W 32 in. LCD Television Logo
    166 people viewed this question
    Top Niko Flat Panel Televisions Experts
    Are you a Niko Flat Panel Television Expert? Answer questions, earn points and help others
