Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Keeps flashing LF - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Call matag tech in california they might still be open
Posted on Jul 29, 2009
1982 chevrolet S10 Only headlights come one with
Voltage for the tail lamps shows to be a brown wire. Use a test light, check that wire for voltage, headlamp switch on. If voltage then check black ground wire.
A problem with grounds will cause some weird things to happen. Ground wires are black. You can use a test light to check ground, one end of testlight comes from battery voltage, the other end you touch ground, black wire, you have to penetrate the insulation. If the lite comes on, at least the ground is good enough for the test light.
At the moment, I don't care about the maker lamps. I do care about tail--stop--turn--tag lamp. In the past, I have been stopped because of no tag light.
Just my opinion.https://s9.postimg.org/af5e5kqtb/tail_lamps.jpg
Click on the link, hope you can read it.
May 30, 2017 | Chevrolet S 10 Cars & Trucks
It keeps stopping flashing LF,I don't have the manual,what does LF mean?
Hello there:
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. furthermore please check the following that may apply
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet
Aug 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does the code LF stand for? It keeps stopping half way through the wash cycle and flashes this code.
LF is for long fill.
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Check the following:
? Is water supply connected and turned on?
? Are hose screens plugged?
? Is water entering the tub?
If all these are good and water is going in fast (both hot and cold) you may need a service company to come out and take a look
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Keep getting an LF error
Hi There
I have found something for to read and this should help you. Try this and let me know how it goes.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya. Merry X-Mass and a Happy New Year.
Best Regards Richard
Dec 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The washer is showing a code of LF what does this mean
LF Long Fill
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WHAT IS THE PROBLEM WHEN YOU GET THE LF ON THE
LF Long Fill
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
DVD drive troubleshooting
Can you explain a dvd cartridge please?
May 04, 2007 | Panasonic LF D521 (LF-D521U)...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
