SOURCE: Nikon 18 to 70 AFS-DX lens focus erroers
I have never heard anyone mention a backfocus problem with this lens. In my experience, most of the backfocus issues that I have worked with to help people resolve have panned out as user error and/or a misunderstanding of the AF modes and performance of the camera. You sound like you know what's up, so that may not apply to you...you may have a real issue. The best thing for you to do before proceding to having is service is test the lens thoroughly on both bodies to see if this is a consistent, reproducable problem or just an anomaly.
SOURCE: Nikon D40x AF-S Nikkor 18-55 mm 1:3.5-5.6 GII ED Lense Trouble
I've found the same thing with my D40x and the 18-55mm AF-S lens. I took a really close look at it and found that the mount on the lens is badly worn on all three of the bayonet tangs and one is cracked at the base. What happens in my case is that the lens has movement when mounted on the camera - just enough to stop the contacts from mating properly. Hence, no photos. Am taking it to Nikon to get it fixed. I suggest if this is your problem, that you take it to the repair man.
SOURCE: Nikon D50 will not auto focus.
Apparently, judging from this site, this is a common problem for this camera. I had mine in for cleaning overseas and they told me the lens was too advanced for the camera-but it worked before!
It sounds like 2 possible fixes are :
#1: making sure the lens is fully clicked in
#2: switching the custom setting from AE-L/AF-L to AE/AF LOCK. This one I just found from a posting on this site and will try it later today!!!!!!
GOOD LUCK! Otherwise I love the camera!
SOURCE: Nikon D3000. Exposure lock with focus problem.
Probably your lens causes this I think. Please check these.
1. Your lens may cause this. Change it and try again.If you do not have another lens then go on to check the next instrutions.
2. Check your lens AF button. It should be switched to AF.
3. Turn off and on the camera and try again.
4. Check your battery charging.
5. Your lens should be cleaned complitely. Please check its clearity.
I think it will work. But if it does not work properly again then your camera should be checked.
Clean your camera mirror. For this:
1. Turn off your camera.
2. Remove your lens.
3. Clean your mirror without using water or any other liquid or any other chemicals. Use only special cleaning liquid that is made for lens cleaning.
4. If it does not work then your camera body should be checked electronically and mechanically. This check can only be done with an authorized service tecnician. So you should send your camera to your service dealer.
