Washer will not start up once you push the button it acts like i want to start and the door lock comes on then goes off.
  • 86 Answers
Make sure the door is closing enough to allow the lock to locate properly,Try this or try replacing switch.Hope this helps.Cheers.
Posted on Jul 29, 2009
Door won/t lock to start washer
by pushing all the buttons the door finally locked and the washer started, thanks anyway.
Sep 29, 2009 | GE Dishwashers
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer not working properly
The reed switch has been removed from the newer washers of same model. Nothing to do with the switch. Open door and turn the drum. This has happened to me a couple times. If the drum will not turn , try putting a little force on it. Mine acted the same and it was a sock that was stuck. Didn;t know what it was until I removed the boot where the coin trap is . and found a sock hanging down from the tub. stick your fingers up it the tub( with washer unplugged) and check for any material that might be there.
Jan 17, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
Aug 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore Front Load Washer 417.44152400 lights up, no activity
Find the button on your panel with a 'key' symbol. Press & hold this down till the lock light goes off. Or
Hold down the 'options' & 'select' buttons together till the lock light goes off. Or
Press and hold down "end of cycle"
Pl. rate & tell me what did it - it is important.
May 23, 2008 | Kenmore 44102 Front Load Washer
Maytag neptune washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washer won't start
First of all, does the washer make a distinctive "click" when you push the START button? This is an indication that your door latch is locking (or at least making an attempt to lock). Normally, however, the display would have an "fdl" fault code indicating a door lock failure if it were bad. I have seen the latch go bad and not register a fault code, though. You can perform this simple diagnostic test to see if any fault codes register: 1. Select DRAIN/SPIN 2. Under SPIN SPEED select NO SPIN 3. Then, under OPTIONS push the PREWASH button 4 times. You should hear the door latch click then "C00" will show on the display. The washer will begin a series of tests (C01...C05 - depending on options and model) by testing the hot and cold fill valves, the various dispenser compartments, followed by tumble, drain and spin. If there is something wrong the diagnostic test will abort and a fault code will be displayed. The washer usually beeps when it displays a fault code. If you attempt to perform the diagnostic and the display momentarily flashes after you press the PREWASH button the fourth time and goes out, this can also be a symptom of bad door latch. You need to perform these simple steps first in order to further diagnose. Let me know what you come up with.
Jun 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
