Question about Kodak EasyShare M853 Digital Camera
Red screen even when i take a pictures
When i take pictures its red with stripes
  • 300 Answers
Hi!
It's probably a loose connection between the CCD and the main board - happens to these cameras quite often. If you're willing to repair it yourself, open it and check the connection. Otherwise you should contact local Kodak service center or other camera service center.
Hope this helps!
Tom
Posted on Jul 29, 2009
Screen is green blue and red vertical stripes, audio is ok
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 06, 2014 | HP Televison & Video
Standard television spot after bright screen
A explanation that may tell you what is happening:
Some of their sets had this issue. The picture tube has a metal screen inside directly behind the stripes that make up the phosphor coating on the inside of the picture tube.
It is called a shadow mask. It has perforations that line up with all the stripes on the screen (look close--red-green-blue stripes all outlined in black--tiny).
What is wrong is not fixable even if the tube is replaced----the metal used in these sets for the mask contains iron which causes it to expand in areas with real bright scene changes--
No need to remove question as I saw it and answer questions for most TV area problems.
I actually ten years ago worked for Circuit City--saw at least 5 sets (all larger Toshiba sets) with this issue. On seeing first one called our support staff and someone explained to me the issue---that set was under extended warranty and since the customer was angry the set was "exchanged" for a brand new set and the old one was disposed of.
Jun 01, 2012 | Curtis-Mathis Televison & Video
My monitor goes half red pin striped and black w/ some visibility
It sounds like you may have connections problem (loose or dirty contacts) between the LCD panel and the logic board, look for that first, worst case will the LCD controller (T-CON) board, which is part of the LCD screen panel assembly. See some pictures here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
Apr 04, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My TV Screen just turned off, but I hear the sound, have no menu.
MINE DID THE SAME THING ABOUT AN HOUR AGO. I UNPLUGGED THE SKY BOX FOR ABOUT 10 MINS PLUGGED IT IN AGAIN IT WAS FINE
Jan 31, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
No picture. Red-blue stripe across screen
there is a computer chip that is now toast on your motherboard. I don't remember the name of it but same happened on my RCA. It is caused by over heating. Over heating is caused by lousy vent design. Its important to place TV on hard surface NOT CARPET. I learned the hard way. The chip that went out is a $15 - $20 part, but finding someone to put it in for cheap is like winning the lotto. hope this helps.
Jun 24, 2009 | Televison & Video
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Light red translucent stripe at top of screen
On your Remote
>menu
>parental controls,favs & setup
>system setup
>display
>centering
You can use this screen to move your picture up a bit and get rid of the line. If it doesnt work the first time, move it a little more. Good Luck!
Aug 03, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Vertical Stripes on My Mitsubishi WS-65809 Projection TV
ADAM,
YOU NEED TO ADJUST THE SCREEN VOLTAGES TO BALANCE IT OUT. YOU CAN DO IT YOUSELF. HERE IS A WEBSITE. PLEASE READ THROUGH IT ALL. ITS FOR RED TINT OR LINES, BUT ITS USE IS FOR THE SAME PROBLEM AND COLORS. HOPFULLY, ON A LITTLE ADJUSTMENT IS ALL IT NEEDS.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
PRIDAH
Nov 22, 2007 | Sony KP-57WS500 57" Rear Projection...
No picture, just red-blue-green lines through the middle of the screen very faint.
The PT-53WX54 is a standard projection set and does not have a bulb. It has 3 separate picture tubes. If you have lost the picture completely, not even on-screen menu, then something has stopped working in your set. It could be a video processor, vertical deflection or possibly a convergence problem. The set should be serviced by a qualified tech familiar with the Panasonic projection sets.
Aug 22, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Kodak EasyShare M853 Digital Camera Logo
102 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
